FMC internal peripheral
  • briefly introduce the FMC peripheral and its main features
  • explain, when needed, how to configure the FMC peripheral.
2. Peripheral overview
The FMC peripheral is used to interface an STM32 MPU with SLC 8-bit or 16-bit NAND Flash memory devices.
The FMC NAND controller supports:
  • Programmable error correction capability (ECC) using BCH8 code, BCH4 code or Hamming code
  • Programmable page size of 2048, 4096 and 8192 bytes
  • Programmable memory timings
  • Multiple dice per package.
2.1. Features
2.2. Security support
The FMC is a non-secure peripheral.
3.1. Boot time
FMC instance is boot device that support serial boot for Flash programming with STM32CubeProgrammer.
3.2. Runtime
3.2.1. Overview
The FMC instance can be allocated to the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the MTD framework
Chapter #Peripheral assignment describes which instance can be assigned to which context.
3.2.2. Software frameworks
| Mass storage
| FMC
| Linux MTD Framework
For Linux kernel configuration, please refer to FMC device tree configuration
3.2.4. Peripheral assignment
| rowspan="1" | Mass storage
| rowspan="1" | FMC
| FMC
4. How to go further
5. References
