SDMMC device tree configuration
This article explains how to configure the SDMMC internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the MMC framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the SDMMC peripheral, used by the STM32 SDMMC Linux driver and by the MMC framework.
The SDMMC device tree bindings are composed of:
  • generic MMC device tree bindings [1].
  • SDMMC MMC/SD/SDIO interface bindings [2].
The SDMMC peripheral node is located in stm32mp157c.dtsi[3] file.
   sdmmc1: sdmmc@58005000 {                                  Template:Highlight
       compatible = "arm,pl18x", "arm,primecell";
       arm,primecell-periphid = <0x00253180>;
       reg = <0x58005000 0x1000>,                            Template:Highlight
             <0x58006000 0x1000>;                            Template:Highlight
       interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;        Template:Highlight
       interrupt-names = "cmd_irq";
       clocks = <&rcc SDMMC1_K>;
       clock-names = apb_pclk
       resets = <&rcc SDMMC1_R>;
       status = "disabled";
Template:Warning
The SDMMC peripheral may connect to one SD card, one eMMC™ device or one SDIO card.
   &sdmmc1{                                                  Template:Highlight
       pinctrl-names = "default", "opendrain", "sleep";      Template:Highlight
       pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>;
       pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>;
       pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>;
       st,neg-edge;                                          Template:Highlight
       st,sig-dir;                                           Template:Highlight
       st,use-ckin;                                          Template:Highlight
       bus-width = <4>;                                      Template:Highlight
       vmmc-supply = <&vdd_sd>;                              Template:Highlight
       vqmmc-supply = <&sd_switch>;                          Template:Highlight
       status = "okay";                                      Template:Highlight
Below optional properties have to be used when an external transceiver is connected:
  • st,sig-dir: This property allows to select external transceiver direction signals polarity. When this property is set, the voltage transceiver IOs are driven as output when the direction signals are high. Without setting this property, the voltage transceiver IOs are driven as output when the direction signals are low.
  • st,use-ckin: By setting this property, the sdmmc_ckin pin from an external transceiver is used to sample the receive data.
Below example shows how to configure the SDMMC when an eMMC™ is connected with 8 data lines [4].
   &sdmmc2{                                                  Template:Highlight
       pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_dir_pins_a>;
       pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_dir_pins_a>;
       pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_dir_sleep_pins_a>;
       non-removable;                                        Template:Highlight
       no-sd;                                                Template:Highlight
       no-sdio;                                              Template:Highlight
       st,neg-edge;
       bus-width = <8>;
       vmmc-supply = <&v3v3>;
       vqmmc-supply = <&vdd>;
       mmc-ddr-3_3v;                                         Template:Highlight
       status = "okay";
Below example shows how to configure the SDMMC to SD card (4 data lines) with an external transceiver [4].
       broken-cd;                                            Template:Highlight
       st,neg-edge;
       st,sig-dir;
       st,use-ckin;
       bus-width = <4>;
       sd-uhs-sdr12;                                         Template:Highlight
       sd-uhs-sdr25;
       sd-uhs-sdr50;
       sd-uhs-ddr50;
       sd-uhs-sdr104;
       status = "okay";
