Pinctrl device tree configuration
1. Purpose[edit source]
The purpose of this article is to explain how to configure the GPIO internal peripheral through the pin controller (pinctrl) framework, when this peripheral is assigned to Linux® OS (Cortex-A). The configuration is performed using the Device tree.
To better understand I/O management, it is recommended to read the Overview of GPIO pins article.
This article also provides an example explaining how to add a new pin in the device tree.
The Pinctrl device tree bindings are composed of:
  • generic DT bindings[1] used by the pinctrl framework.
  • vendor pinctrl DT bindings[2] used by the stm32-pinctrl driver: this binding document explains how to write device tree files for pinctrl.
The pin controller node is located in the pinctrl dtsi file stm32mp157-pinctrl.dtsi[3]. See Device tree for more explanations about device tree file split. The pin controller node is composed of three parts:
3.1.1. STM32 pin controller information[edit source]
pinctrl: pin-controller {                 Template:Highlight
 	#address-cells = <1>;
 	#size-cells = <1>;
 	ranges = <0 0x50002000 0xa400>;    Template:Highlight
 	interrupt-parent = <&exti>;        Template:Highlight
 	st,syscfg = <&exti 0x60 0xff>;     Template:Highlight
 	pins-are-numbered;
Template:Warning
3.1.2. GPIO bank information[edit source]
	gpioa: gpio@50002000 {
		gpio-controller;
		#gpio-cells = <2>;
		interrupt-controller;      Template:Highlight
		#interrupt-cells = <2>;
		reg = <0x0 0x400>;         Template:Highlight
		clocks = <&rcc GPIOA>;     Template:Highlight
		st,bank-name = "GPIOA";
		status = "disabled";
	gpiob: gpio@50003000 {
		gpio-controller;
		#gpio-cells = <2>;
		reg = <0x1000 0x400>;
		clocks = <&rcc GPIOB>;
		st,bank-name = "GPIOB";
Template:Warning
3.1.3. Pin state definition[edit source]
- Extract of stm32mp157c-pinctrl.dtsi[3] file:
         usart3_pins_a: usart3@0 {                                                   Template:Highlight
	        pins1 {
		        pinmux = <STM32_PINMUX('B', 10, AF7)>, /* USART3_TX */      Template:Highlight
			         <STM32_PINMUX('G', 8, AF8)>; /* USART3_RTS */      Template:Highlight
		        bias-disable;                                               Template:Highlight
		        drive-push-pull;                                            Template:Highlight
		        slew-rate = <0>;                                            Template:Highlight
	        pins2 {
		        pinmux = <STM32_PINMUX('B', 12, AF8)>, /* USART3_RX */
			         <STM32_PINMUX('I', 10, AF8)>; /* USART3_CTS_NSS */
		        bias-disable;
- Refer to GPIO internal peripheral for more details on hardware pin configuration.
As seen in Pin controller configuration (pin state definition part), all pin states are defined inside the pin controller node.
Each device that requires pins has to select the desired pin state phandle inside the board device tree file (see Device tree for more explanations about device tree file split).
The STM32MP1 devices feature a lot of possible pin combinations for a given internal peripheral. From one board to another, different sets of pins can consequently be used for an internal peripheral. Note that "_a", "_b" suffixes are used to identify pin muxing combinations in the device tree pinctrl file. The right suffixed combination must then be used in the device tree board file.
  • Example:
&usart3 {
	pinctrl-names = "default","sleep";
	pinctrl-0 = <&usart3_pins_a>;
	pinctrl-1 = <&usart3_sleep_pins_a>;
3.3.1. How to add new pin states[edit source]
To add new pin states and affect them to a foo_device, proceed as follows:
1. Find the pins you need:
In the example below, the foo_device needs to configure PC13, PG8 and PI2.
AF2 is selected as alternate function on PC13, and AF5 on PG8 and PI2.
Each pin requires an internal pull-up.
2. Write your pin state phandle in stm32mp157c-pinctrl.dtsi.
          foo_pins_a: foo@0 {
 	        pins {
 		        pinmux = <STM32_PINMUX('C', 13, AF2)>,
                                 <STM32_PINMUX('G', 8, AF5)>,
 			         <STM32_PINMUX('I', 2, AF5)>;
 		        bias-pull-up;
All the possible settings are described in GPIO internal peripheral.
3. Select the pin state phandle required for your device in the board file.
&foo {
	pinctrl-names = "default";
	pinctrl-0 = <&foo_pins_a>;
4. How to configure GPIOs using STM32CubeMX[edit source]
  1. Template:CodeSource, Generic pinctrl device tree bindings
  2. Template:CodeSource, STM32 pinctrl device tree bindings
  3. Jump up to: 3.0 3.1 Template:CodeSource STM32MP157C Pinctrl device tree file
