LPTIM internal peripheral
  • briefly introduce the LPTIM peripheral and its main features
  • explain how to configure the LPTIM peripheral
2. Peripheral overview
The LPTIM peripheral is a single channel low-power timer unit, that can continue to run even during low power modes when it selects a clock source that remains active in RCC.
2.1. Features
The LPTIM peripheral is available in different configurations, depending on the selected instance :
  • LPTIM1 and LPTIM2 can act as PWM, quadrature encoder[1], external event counter, trigger source for other internal peripherals like: ADC[2], DAC[3], DFSDM[4].
  • LPTIM3 can act as PWM, external event counter, trigger source for other internal peripherals like ADC[2], DFSDM[4].
  • LPTIM4 and LPTIM5 can act as PWM.
2.2. Security support
The LPTIM is a non-secure peripheral.
3.1. Boot time
The LPTIM is not used at boot time.
3.2. Runtime
3.2.1. Overview
LPTIM instances can be allocated to:
  • the Arm® Cortex®-A7 non-secure to be used under Linux® with PWM, IIO, Counter or/and Clock events frameworks,
  • the Arm® Cortex®-M4 to be used with STM32Cube MPU Package with LPTIM HAL driver
3.2.2. Software frameworks
non-secure
Cortex-M4
Core/Timers LPTIM PWM framework,
IIO framework,
Counter framework,
STM32Cube LPTIM driver
The configuration is applied by the firmware running in the context to which the peripheral is assigned. The configuration by itself can be performed via STM32CubeMX tool for all internal peripherals. It can then be manually completed (especially for external peripherals) according to the information given in the corresponding software framework article.
For Linux kernel configuration, please refer to LPTIM device tree configuration and STM32 LPTIM Linux driver articles.
3.2.4. Peripheral assignment
Internal peripherals
non-secure
Cortex-M4
Core/Timers LPTIM LPTIM1 Assignment (single choice)
LPTIM2 Assignment (single choice)
LPTIM3 Assignment (single choice)
LPTIM4 Assignment (single choice)
LPTIM5 Assignment (single choice)
4. References
