GTK demo launcher
This article provides information on the Demo Launcher application. The Demo Launcher starts by default with the Starter Package. This application is written in pythonTM3[1] and uses GTK[2] to display the user interface. A touchscreen is required to control the application.
1. Main menu[edit source]
Main menu
Display the preview from /dev/video0.
  • On STM32MP157C-DKX boards, a USB webcam can be used
  • On STM32MP157C-EVX boards, either a MB1379 camera daughter board or a USB webcam can be used.
Ensure that the webcam is compatible with Linux®.
  • Simple tap: pause-resume the camera preview.
More information on V4L2 is available in V4L2 camera overview and how is managed the display in Wayland_Weston_overview.
Video Playback
  • First tap: as video is composed by Wayland, the first tap has to be done outside the video playback window to recover the GTK focus
More information on Gstreamer is available in GStreamer_overview and how is managed the display in Wayland_Weston_overview.
5. Artificial Intelligence[edit source]
1) Draw a character on the screen. It is then analysed by the firmware running on Arm® Cortex®-M4 side.
2) If the character is recognized, it is displayed on the left. If it is not, a question mark is displayed.
  • A: to launch audio playback
  • C: to launch camera preview
  • P: to display a picture
  • V: to launch a video playback
  • S: to stop the launched application
  • Q: to exit from the Artificial Intelligence demo.
It is possible to start several instances of the same application (for example three audio playbacks at the same time). This is not recommended
6. 3D GPU[edit source]
3D GPU
  • Continuous tap : a continuous press on screen will drag the cube.
  • Double tap: exit from this window, double tap anywhere on the screen.
More information on how is managed the display in Wayland_Weston_overview.
Bluetooth speaker
This application is able to discover Bluetooth® devices, and pair/connect to them. If an audio capable device is connected, the message The audio BT device <your device> is connected is displayed.
First use:
1) Tap on start scan button: a scan of discoverable devices is done during 15 seconds. The scroll bar progression is displayed.
2) Select the device in the list, and tap on connect.
If the device is already connected, the "disconnect button is displayed instead.
More information on Bluetooth® is available in Bluetooth_overview.
8. Info menu[edit source]
Info menu
Click on the "i" icon on the right of the screen. It displays the menu describing how to use the demos. To exit from this window, double tap anywhere on the screen.
Add a new demo application is possible with ecosystem release ≥ v1.2.0 .
The GTK demo launcher is scalable which means new application can be added. The GTK demo launcher uses specific yaml files to automatically detect which application to display.
An application on GTK demo launcher:
  • is described by a yaml file which gives the application details e.g.: information to display, how to launch it, ...
  • is indexed to be displayed in specific order,
  • must be launched on full screen
  • must manage the QUIT/EXIT
For scalability of an application is managed by:
  • an indexed yaml file (meaning that file is prefixed by a number which indicate the order to display the application on GTK demo launcher)
  • a sub-tree which contains any pictures and any mandatory script to run application.
Sub-tree example for video application:
 /usr/local/demo/application/
 ├── 02-video.yaml
 └── video
     ├── bin
     │   └── launch_video.sh
     └── pictures
For usage of gstreamer graph in case of camera preview, video playback, ... an application are available.
touch-event-gtk-player: permit to play a gstreamer graph and manage play/pause event via a simple click/touch and manage quit/exit of playback via double click/touch.
/usr/local/demo/bin/touch-event-gtk-player --graph "<gstreamer graph>"
Below is given an example of format used to describe an application.
 Application:
    Name: <name of application>
    Icon: <icon of application>
    Type: <script|python>
    Board:
    Script:
        Exist:
    Python:
        Exist:
    Action:
Parameters description:
Name
application name displayed on GTK demo launcher.
Description
application description displayed on GTK demo launcher.
Icon
application icon to be displayed on GTK demo launcher.
Board
List: list of STM32MPU devices which are compatible with the application.
NotList: List of STM32MPU devices which are not compatible with the application.
Type
Types of script which can be used to launch the application.
Available types:
  • script : shell script or application (without parameters) to use for launching application.
  • python: Python script to load for launching application.
Both types have a specific declaration available: script", "python".
Script
This section has 3 sub-sections:
  • Exist: list requirements that must be verified before launching start command
  • Start: identify the command that starts the application
Exist
  • File: to verify the presence of a specific file. If files are present then the application can be launched with Start
  • Command: to check if command to execute exist. If "Ok" is returned then application can be launched with Start
Example
        Exist:
            File: /dev/video0
                    /dev/video0 doesn't exist
Python
This section describes the PythonTMscript to load to access the application functionality.
The PythonTM script must have the function create_subdialogwindow(<parent window>).
This section sub-divided into several sub-sections
  • Module: PythonTM module name to load, it corresponds to the path and script name.
Example
     for a path application/netdata/netdata.py,  module name must be application.netdata.netdata
'Tips: you need to add an empty file name "__init__.py" on each sub-directory to be able to launch the PythonTM module
Exist
  • File: checks the presence of specific files. If the files are present the application can be launched with Start
  • Command: command to execute, if "OK" is returned the application can be launched with Start
Example
        Exist:
            Command: hciconfig hci0 up
9.2. File Tree[edit source]
Example of sub-tree used by GTK demo launcher.
 ├── 000-netdata.yaml
 ├── 010-camera.yaml
 ├── 020-video.yaml
 ├── 030-3d_cube.yaml
 ├── 040-m4_ai.yaml
 ├── 3d_cube
 │   ├── bin
 │   │   └── launch_cube_3D.sh
 │   └── pictures
 ├── bluetooth
 │   ├── bluetooth_audio.py
 │   ├── __init__.py
 │   ├── pictures
 │   └── wrap_blctl.py
 ├── camera
 │   ├── bin
 │   ├── pictures
 │   └── shaders
 ├── __init__.py
 ├── m4_ai
 │   ├── bin
 │   │   └── launch_AI.sh
 │   └── pictures
 ├── netdata
 │   ├── bin
 │   │   └── build_qrcode.sh
 │   ├── __init__.py
 │   ├── netdata.py
 │   └── pictures
 └── video
     ├── bin
     └── pictures
9.3.1. with Script, verification of presence of device and board support[edit source]
Application:
    Description: GPU with picture
    Board:
        NotList: stm32mp151
    Type: script
    Script:
        Exist:
            File: /dev/galcore
    Action:
9.3.2. with Script and verification of presence of device[edit source]
Application:
    Description: shader
    Board:
        List: all
    Type: script
    Script:
        Exist:
            File: /dev/video0
    Action:
9.3.3. with PythonTM and verification via command[edit source]
Application:
    Description: speaker
    Type: Python
    Board:
        List: stm32mp157 stm32mp153
    Python:
        Exist:
    Action:
With ecosystem release ≥ v1.2.0 is delivered an example of recipe useful to add an application (demo-application-3d-cube) in the GTK demo launcher. It is available at this location:
When creating the recipe, some attention points must be checked:
  • Put a correct index for yaml file name which determine the order to display the application (see example below)
  • Install all the appropriate application sub-tree in /usr/local/demo/application,
  • The application launched must be launched on full screen and must manage QUIT/EXIT.
chmod 0755 <script name>
  • Sub-tree example for the demo-application-3d-cube:
├── 100-3d-cube.yaml
├── 101-3d-cube-shader.yaml
├── 110-3d-cube-video.yaml
├── 115-3d_cube_camera.yaml
└── 3d-cube-extra
    ├── bin
    └── pictures
  • Associated recipe:
HOMEPAGE = "wiki.st.com"
LICENSE = "BSD-3-Clause"
SRC_URI = " \
    file://100-3d-cube.yaml \
do_configure[noexec] = "1"
do_compile[noexec] = "1"
do_install() {
    # install yaml file
    # install bin
    # install pictures
If the GTK demo launcher is not yet installed
 dpkg -l | grep demo-launcher
It can be installed with the following command:
apt-get update
apt-get install demo-launcher
To add 3D application:
10. References[edit source]
