Perfetto
This article provides the basic information required to start using the perfetto [1] Android™ tool.
1. Introduction[edit source]
perfetto Tracing tools perfetto[1] is a performance instrumentation and tracing tool for Android™.
  • Open-source project for platform tracing
  • Trace processing and analysis
  • Web-based trace viewer UI
No No No Yes* Yes* Yes
2. Getting started with perfetto[edit source]
Perfetto instructions can be generated using the recording tool[2].
  • Create record settings required
  • Copy generated instructions
  • Execute the copied instructions on a opened terminal with the device connected through USB, having ADB installed.
At the end of the trace execution, you can get back the trace:
 adb pull /data/misc/perfetto-traces/trace
From this stage you can directly open the trace through the web viewer[3].
3. References[edit source]
