The purpose of this article is to explain how to configure the CRYP[1] when the peripheral is assigned to Linux® OS.
The Device tree provides a hardware description of the CRYP[1], used by STM32 CRYP Linux driver.
2. DT bindings documentation
The CRYP [1] is represented by the STM32 CRYP device tree bindings[3].
3. DT configuration
This hardware description is a combination of STM32 microprocessor and board device tree files. See Device tree for explanations on device tree file split.
The STM32CubeMX can be used to generate the board device tree. Refer to #How_to_configure_the_DT_using_STM32CubeMX for more details.
The CRYP node is declared in stm32mp157c.dtsi[4]. It provides the hardware registers base address, clock, interrupt and reset.
cryp1: cryp@54001000 {
compatible = "st,stm32mp1-cryp";
reg = <0x54001000 0x400>;
interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc CRYP1>;
resets = <&rcc CRYP1_R>;
status = "disabled";
This part is used to enable the CRYP used on a board. This is done by setting the status property to okay.
&cryp1 {
status = "okay";
5. References
