This article explains how to configure the GPU internal peripheral when it is assigned to the Linux® OS.
The configuration is performed using the device tree mechanism that provides a hardware description of the GPU internal peripheral, used by the STM32 GPU Linux driver.
2. DT bindings documentation
The GPU is represented by the STM32 GPU device tree bindings [1].
3. DT configuration
The GPU device tree node is declared in stm32mp157c.dtsi [2]. The declaration (shown below) defines the hardware registers base address, the interrupt, the clocks and the reset.
gpu: gpu@59000000 {
compatible = "vivante,gc";
reg = <0x59000000 0x800>;
interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&rcc GPU>, <&rcc GPU_K>;
clock-names = "bus" ,"core";
resets = <&rcc GPU_R>;
status = "disabled";
5. References
