- briefly introduce the DAC peripheral and its main features
- explain how to configure the DAC peripheral.
The DAC peripheral is a voltage output digital-to-analog converter.
2.1. Features[edit source]
- It may be configured in 8- or 12-bit mode (data could be left- or right-aligned)
- It has two output channels, each with its own converter
- The dual DAC channel mode could be done independently or simultaneously
- It has built-in noise and triangle waveform generator and supports triggers for conversions, using: TIM[1], LPTIM[2] or EXTI[3]
- The DAC output buffer allows a high drive output current
- It can operate under Normal mode or low-power Sample and Hold mode (uses LSI clock, from RCC[4]).
- It may be used in conjunction with the DMA[5] controller (with underrun error detection)
- The common reference voltage, can be provided by either VREFBUF[6] or any other external regulator[7] wired to VREF+ pin.
The DAC is a non-secure peripheral.
3.1. Boot time[edit source]
The DAC is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DAC instances can be allocated to:
- the Arm® Cortex®-A7 non-secure core to be used under Linux® with the IIO framework
- the Arm® Cortex®-M4 core to be used with STM32Cube Package with STM32Cube DAC driver.
The Peripheral assignment chapter describes which peripheral instance can be assigned to which context.
Cortex-A7 secure (OP-TEE) |
Cortex-M4 (STM32Cube) | |||
Analog | DAC | Linux IIO framework | STM32Cube DAC driver |
For the Linux kernel configuration, please refer to DAC device tree configuration and DAC Linux driver articles.
Analog | DAC | DAC | ☐ | ☐ | Assignment (single choice) |
4. References[edit source]
