CRYP internal peripheral
  • briefly introduce the CRYP peripheral and its main features
  • explain how to configure the CRYP peripheral.
2. Peripheral overview
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
2.1. Features
2.2. Security support
CRYP1 is a secure peripheral (under ETZPC control).
CRYP2 is a non secure peripheral.
3.1. Boot time
CRYP1 is not used during boot process.
3.2. Runtime
CRYP1 instance can be allocated to:
CRYP2 instance can be allocated to:
3.2.1. Software frameworks
non-secure
Cortex-M4
Security CRYP CRYP OP-TEE driver Linux Crypto framework STM32Cube CRYP driver
3.2.2. Peripheral configuration
3.2.3. Peripheral assignment
Internal peripherals
non-secure
Cortex-M4
Security CRYP CRYP1 Assignment (single choice)
CRYP2
4. How to go further
Not applicable.
5. References
