Template:ArticleMainWriter
- briefly introduce the HDP peripheral (hardware debug port) and its main features
- explain, when needed, how to configure the HDP peripheral.
2. Peripheral overview
The HDP peripheral is used to output some internal signals on up to 8 GPIO pins.
Follow the sequence below to connect a GPIO to an internal signal via the HDP:
- First of all, look for the internal signal you want to monitor in the HDP signal multiplexing table of the STM32MP15 reference manuals:
- Search for the HDP signal on which you can get it among eight possible choices.
- Note the corresponding HDPx multiplexing value to select.
- Then, look for the most suitable GPIO pin on which you can output HDPx in the datasheet:
The GPIO bank, pin, alternate function and HDPx multiplexing value are the information required to configure each HDP signal.
2.1. Features
2.2. Security support
The HDP is a non-secure peripheral.
3.1. Boot time
The HDP is not used at boot time.
3.2. Runtime
3.2.1. Overview
The HDP can be allocated to the Arm® Cortex®-A7 non-secure core to be used under Linux® HDP driver.
3.2.2. Software frameworks
Cortex-A7 secure (OP-TEE) |
Cortex-M4 (STM32Cube) | |||
Trace & Debug | HDP | HDP Linux driver |
3.2.4. Peripheral assignment
Trace & Debug | HDP | HDP | ☐ |
