HASH device tree configuration
This article explains how to configure the HASH internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Crypto framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the HASH peripheral, used by the STM32 HASH Linux driver.
2. DT bindings documentation
The HASH is represented by the STM32 HASH device tree bindings[1]
3. DT configuration
The HASH node is declared in stm32mp157c.dtsi[2]. It describes the hardware register address, clock, interrupt, reset and dma.
 hash1: hash@54002000 {                                                        Template:Highlight
 	compatible = "st,stm32f756-hash";
 	reg = <0x54002000 0x400>;                                               Template:Highlight
 	interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>;                          Template:Highlight
 	clocks = <&rcc HASH1>;
 	resets = <&rcc HASH1_R>;
 	dmas = <&mdma1 31 0x10 0x1000A02 0x0 0x0 0x0>;                          Template:Highlight
 	dma-names = "in";
 	dma-maxburst = <2>;
 	status = "disabled";
Template:Warning
This part is used to enable the HASH used on a board which is done by setting the status property to okay.
&hash1 {
	status = "okay";
5. References
