DAC internal peripheral
Template:ReviewsComments
  • briefly introduce the DAC peripheral and its main features
  • explain how to configure the DAC peripheral.
The DAC peripheral is a voltage output digital-to-analog converter.
2.1. Features[edit source]
  • It may be configured in 8- or 12-bit mode (data could be left- or right-aligned)
  • It has two output channels, each with its own converter
  • The dual DAC channel mode could be done independently or simultaneously
  • It has built-in noise and triangle waveform generator and supports triggers for conversions, using: TIM[1], LPTIM[2] or EXTI[3]
  • The DAC output buffer allows a high drive output current
  • It can operate under Normal mode or low-power Sample and Hold mode (uses LSI clock, from RCC[4]).
  • It may be used in conjunction with the DMA[5] controller (with underrun error detection)
  • The common reference voltage, can be provided by either VREFBUF[6] or any other external regulator[7] wired to VREF+ pin.
The DAC is a non-secure peripheral.
3.1. Boot time[edit source]
The DAC is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DAC instances can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be used under Linux® with the IIO framework
The Peripheral assignment chapter describes which peripheral instance can be assigned to which context.
Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Analog DAC Linux IIO framework STM32Cube DAC driver
For the Linux kernel configuration, please refer to DAC device tree configuration and DAC Linux driver articles.
Internal peripherals
means that the peripheral can be assigned () to the given runtime context.
is used for system peripherals that cannot be unchecked because they are statically connected in the device.
Instance Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Analog DAC DAC Assignment (single choice)
4. References[edit source]
