MDMA device tree configuration
This article explains how to configure the MDMA internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Dmaengine overview.
The configuration is performed using the Device tree mechanism that provides a hardware description of the MDMA internal peripheral, used by the STM32 MDMA Linux driver and by the DMA framework.
Hardware description is a combination of:
  • STM32 MDMA peripheral
  • and STM32 MDMA client
2. DT bindings documentation
3. DT configuration
At device level, MDMA declared is declared as follows:
mdma1: dma@58000000 {
    compatible = "st,stm32h7-mdma";
    reg = <0x58000000 0x1000>;
    interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
    clocks = <&rcc MDMA>;
    #dma-cells = <6>;
    dma-channels = <32>;
    dma-requests = <48>;
The DTS file is located Under Template:CodeSource.
Template:Warning
The whole configuration remains at STM32 level.
5. References
