The purpose of this article is to explain how to configure the CRC[1] when the peripheral is assigned to Linux® OS.
The Device tree provides a hardware description of the CRC[1], used by STM32 CRC Linux driver.
2. DT bindings documentation
The CRC [1] is represented by the STM32 CRC device tree bindings[3]
3. DT configuration
This hardware description is a combination of STM32 microprocessor and board device tree files. See Device tree for explanations on device tree file split.
The STM32CubeMX can be used to generate the board device tree. Refer to #How_to_configure_the_DT_using_STM32CubeMX for more details.
The CRC node is declared in stm32mp157c.dtsi[4]. It provides the hardware registers base address and the clock.
crc1: crc@58009000 {
compatible = "st,stm32f7-crc";
reg = <0x58009000 0x400>;
clocks = <&rcc CRC1>;
status = "disabled";
This part is used to enable the CRC used on a board. This is done by setting the status property to okay.
&crc1 {
status = "okay";
5. References
