MDMA internal peripheral
  • briefly introduce the MDMA peripheral and its main features
  • explain, when necessary, how to configure the MDMA peripheral.
Template:ReviewsComments
2. Peripheral overview
The MDMA is used to perform high-speed data transfers between memory and memory or between peripherals and memory. The MDMA controller features 32 channels, dedicated to DMA transfers. The selection of the device connected to each channel and controlling DMA transfers is directly done by the MDMA.
Among all the requestor lines described in the STM32MP15 reference manuals, DMA channels are the only lines that allow to perform transfers with chained DMA and MDMA (refer to DMA internal peripheral article). As a result, when a device is not connected to the MDMA, it is anyway possible to operate in DMA mode via the DMA controller and chain DMA and MDMA.
2.1. Features
2.2. Security support
The MDMA is a secure peripheral. This means that it performs each transfer in the context of the master that requested it:
  • a transfer requested by the Arm® Cortex®-A7 non-secure core propagates non-secure accesses to the targeted device and/or memory.
  • a transfer requested by Arm Cortex-A7 secure core propagates secure accesses to the targeted device and/or memory.
3.1. Boot time
The MDMA is used at boot time by the FMC.
3.2. Runtime
3.2.1. Overview
The MDMA is visible from the Arm Cortex-M4 core. However, it is not supported in this context by STMicroelectronics distribution.
As stated in the 'Security support' chapter above, the MDMA is a secure peripheral. This means that its channels have to be allocated to:
  • the Arm Cortex-A7 non-secure core to be controlled in Linux® by the dmaengine framework
and
  • the Arm Cortex-A7 secure core to be controlled by the MDMA OP-TEE driver
STM32CubeMX allows to distinguish between non-secure and secure channels, among all the available channels.
3.2.2. Software frameworks
3.2.4. Peripheral assignment
Internal peripherals
means that the peripheral can be assigned () to the given runtime context.
is used for system peripherals that cannot be unchecked because they are statically connected in the device.
4. How to go further
Not applicable
5. References
