- briefly introduce the DBGMCU peripheral and its main features
- explain, when necessary, how to configure the DBGMCU peripheral.
2. Peripheral overview
The DBGMCU peripheral is used to configure internal peripherals behavior when one of the cores (CortexTemplate:Sup-A7 or CortexTemplate:Sup-M4) enters in debug mode.
For instance, it allows to freeze a watchdog (IWDG) to avoid getting a watchdog reset when the CortexTemplate:Sup-A7 enters in debug mode (via a breakpoint or JTAG break).
2.1. Features
2.2. Security support
The DBGMCU is a non secure peripheral.
3.1. Boot time
DBGMCU is partly initialized by the FSBL at boot time in order to freeze IWDG2 when the CortexTemplate:Sup-A7 enters in debug mode.
3.2. Runtime
3.2.1. Overview
There is no real runtime support for DBGMCU. Instead, users who need to freeze some peripherals for a debug session should complete the minimal initialization done in the FSBL with their needs.
3.2.2. Software frameworks
Cortex-A7 S (OP-TEE) |
Cortex-A7 NS (Linux) |
Cortex-M4 (STM32Cube) | |||
Trace & Debug | DBGMCU |
3.2.4. Peripheral assignment
Trace & Debug | DBGMCU | DBGMCU | No assignment |
