GIC internal peripheral
  • briefly introduce the GIC peripheral (generic interrupt controller) and its main features
  • explain, when needed, how to configure the GIC peripheral.
The GIC peripheral is the Arm® Cortex®-A7 interrupt controller. It is consequently not accessible from the Arm® Cortex®-M4 core.
2.1. Features[edit source]
The GIC is a secure peripheral (under ETZPC control).
3.1. Boot time[edit source]
The GIC is configured by the FSBL (see Boot chains overview), mainly to define the routing of each interrupt to the secure or non-secure context at runtime: this configuration is further described in STM32MP15 interrupts article.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The GIC can be allocated:
  • to the Arm® Cortex®-A7 secure core to be used under OP-TEE with the GIC OP-TEE driver (or TF-A secure monitor if the OP-TEE is not present)
  • or to the Arm® Cortex®-A7 non-secure core to be used under Linux® with the interrupts framework
non-secure
Cortex-M4
Core/Interrupts GIC OP-TEE GIC driver Linux interrupt framework
Internal peripherals
non-secure
Cortex-M4
Core/Interrupts GIC GIC
