How to record audio
2. Audio record overview
The application audio streams are routed by default through the PulseAudio sound server. PulseAudio exposes audio profiles, which are mapped on the ALSA sound card audio devices. The PulseAudio server provides a command line interface to list audio profiles and to select one, in order to record from a specific audio interface.
3. Examples
 arecord -D record_codec -f S16_LE -d 10 /tmp/rec.wav
3.1.2. Record via PulseAudio
  • Configure Pulseaudio :
Change Pulseaudio default input source to 'analog_input':
 pacmd set-default-source analog_input
  • Start audio record :
 arecord -d 10 /tmp/rec.wav
 arecord -D record_dfsdm0 -r 16000 -f S32_LE -c 1 -d 10 /tmp/rec.wav
Start stereo audio record from 'multi' ALSA device:
 arecord -D multi -r 16000 -f S32_LE -c 2 -d 10 /tmp/rec.wav
3.2.3. Record via PulseAudio
The record via Pulseaudio is only available for ecosystem release ≥ v1.2.0 More info.png.
Change Pulseaudio default input source to 'dmic1_input':
 pacmd set-default-source dmic1_input
 arecord -r 48000 -f S32_LE -c 2 -d 10 /tmp/rec.wav
3.3.1. Get IEC958 status bits
 amixer -c STM32MP1EV cget iface=PCM,name='IEC958 Capture Default'
3.3.2. Record from ALSA device
 arecord -D record_spdif -f S32_LE -c 2 -r 48000 -d 10 /tmp/rec.wav
3.3.3. Record via PulseAudio
Change Pulseaudio default input source to 'iec958_input':
 pacmd set-default-source iec958_input
4. References
