CRYP internal peripheral
  • briefly introduce the CRYP peripheral and its main features
  • explain how to configure the CRYP peripheral.
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
2.1. Features[edit source]
CRYP1 is a secure peripheral (under ETZPC control).
CRYP2 is a non secure peripheral.
3.1. Boot time[edit source]
CRYP1 is not used during boot process.
3.2. Runtime[edit source]
CRYP1 instance can be allocated to:
CRYP2 instance can be allocated to:
3.2.1. Software frameworks[edit source]
non-secure
Cortex-M4
Security CRYP CRYP OP-TEE driver Linux Crypto framework STM32Cube CRYP driver
3.2.2. Peripheral configuration[edit source]
3.2.3. Peripheral assignment[edit source]
Internal peripherals
non-secure
Cortex-M4
Security CRYP CRYP1 Assignment (single choice)
CRYP2
Not applicable.
