CRYP internal peripheral
  • briefly introduce the CRYP peripheral and its main features
  • explain how to configure the CRYP peripheral.
2. Peripheral overview
The CRYP peripheral provides hardware acceleration to encrypt or decrypt data using the DES[1], TDES[2] or AES[3] algorithms. It also supports multiple key sizes and chaining modes.
2.1. Features
2.2. Security support
CRYP1 is a secure peripheral (under ETZPC control).
CRYP2 is a non secure peripheral.
3.1. Boot time
CRYP1 is first initialized by the ROM code and used for authentication processing. It is also used by FSBL (TF-A) during the authentication process (using ROM code services).
3.2. Runtime
CRYP1 instance can be allocated to:
CRYP2 instance can be allocated to:
3.2.1. Software frameworks
3.2.2. Peripheral configuration
3.2.3. Peripheral assignment
Internal peripherals
means that the peripheral can be assigned () to the given runtime context.
is used for system peripherals that cannot be unchecked because they are statically connected in the device.
4. How to go further
Not applicable.
5. References
