Getting started with EXTI
(Redirected from EXTI feature overview)
This article explains the EXTI and its use, with examples.
1 What is an external interrupt/event controller (EXTI)
The EXTI (EXTernal Interrupt/Event) controller consists of up to 40 edge detectors for generating event/interrupt requests on STM32L47x/L48x devices. Each input line can be independently configured to select the type (interrupt or event) and the corresponding trigger event (rising, falling, or both).
2 Configure EXTI to turn on a LED when a user button is pressed
2.1 Objective
Learn how to use the external interrupt and turn ON a LED when user button is pressed.
  • Configure the GPIO that is connected to the user Button as External Interrupt (EXTI) with falling edge trigger using STM32CubeIDE
  • Learn how to configure the Interrupt Controller : the NVIC
  • Verify the correct functionality by pressing a button that turns on a LED
2.2 Create the project in STM32CubeIDE
  • File > New > STM32 Project in main panel.
In this example the NUCLEO-L476RG board is used.
  • Select NUCLEO-L476RG in board Selector.
  • Save the project
2.3 Configure GPIO
  • Configure the LED pin as GPIO_Output (PA5 on NucleoFL476RG). For other boards check their user manual.
  • Configure a button pin as GPIO_EXTI (PC13 on NucleoL467RG). For other boards check their user manual.
  • Check GPIO configuration
Make sure to select 'External interrupt mode with Falling edge trigger detection as GPIO Mode!
  • Enable the interrupt for EXTI
2.4 Generate project and edit main.c
  • The easiest way to generate the code is to save your current project: Ctrl + S
The code is generated so you can see it in the left side of the screen in the project explorer
2.4.1 HAL Library workflow summary
The HAL library provides a high-level access to STM32 peripherals like the EXTI.
The HAL_EXTI0_IRQHandler and EXTI0_IRQHandler are inside stm32l4xx_it.c file.
You must define the Callback function in the main.c : HAL_GPIO_EXTI_Callback.
600px
2.4.2 Configure the Interrupt
Create a function to handle the EXTI interrupts:
  • HAL callback function for EXTI: void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
  • To turn an LED on we need to use the function: HAL_GPIO_WritePin
Put the functions into main.c
Insert your code between /* USER CODE BEGIN 4 */ and /* USER CODE END 4 */ tags
  if(GPIO_Pin == GPIO_PIN_13) {
    HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
  } else {
      __NOP();
2.5 Compile and flash
=> When you press the blue button on your board the LED must switch on.
