This step explains how to connect your host Linux® terminal to your host computer through the ST-LINK/V2-1.
It then describes how to execute basic commands with the Linux command line interface in order to order to get familiar with the Linux console.
2. Serial terminal[edit | edit source]
The serial terminal allows communicating with the board through an UART serial interface.
  • Install minicom
 sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
 ls /dev/ttyACM*
/dev/ttyACM0
 minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z for help on special keys
  • Press the reset button to reset the board. The boot log should be displayed on the minicom window:
NOTICE:  CPU: STM32MP157FAA Rev.Z
NOTICE:  Model: STMicroelectronics STM32MP157F eval daughter on eval mother
NOTICE:  Board: MB1263 Var4.0 Rev.C-03
INFO:    PMIC version = 0x20
INFO:    Reset reason (0x54):
INFO:      System reset generated by MPU (MPSYSRST)
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:    FCONF: Reading firmware configuration information for: stm32mp_io
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.8-stm32mp1-r1.0(debug):lts-v2.8.6-dirty(ff0bd5f9)
NOTICE:  BL2: Built : 17:57:15, Apr 21 2023
INFO:    RAM: DDR3-DDR3L 32bits 533000kHz
INFO:    Memory size = 0x40000000 (1024 MB)
INFO:    BL2: Loading image id 1
INFO:    Loading image id=1 at address 0x2ffff000
INFO:    Image id=1 loaded: 0x2ffff000 - 0x2ffff1ea
INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
INFO:    FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO:    Loading image id=4 at address 0xfe000000
INFO:    Image id=4 loaded: 0xfe000000 - 0xfe00001c
INFO:    OPTEE ep=0xfe000000
INFO:    OPTEE header info:
INFO:          magic=0x4554504f
INFO:          version=0x2
INFO:          arch=0x0
INFO:          flags=0x0
INFO:          nb_images=0x1
INFO:    BL2: Loading image id 8
INFO:    Loading image id=8 at address 0xfe000000
INFO:    Image id=8 loaded: 0xfe000000 - 0xfe036bb8
INFO:    BL2: Skip loading image id 9
INFO:    BL2: Loading image id 2
INFO:    Loading image id=2 at address 0xc0500000
INFO:    Image id=2 loaded: 0xc0500000 - 0xc05217a8
INFO:    BL2: Skip loading image id 16
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01f5d3c
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0xfe000000
INFO:    SPSR = 0x1d3
I/TC: Early console on UART#4
I/TC:
I/TC: Embedded DTB found
I/TC: OP-TEE version: 3.19.0-dev (gcc version 12.2.0 (GCC)) #1 Fri Oct 14 19:00:05 UTC 2022 arm
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Platform stm32mp1: flavor PLATFORM_FLAVOR - DT stm32mp157f-ev1.dts
I/TC: DTB enables console (non-secure)
I/TC: Primary CPU switching to normal world boot
optee optee: OP-TEE: revision 3.19 (afacf356)
U-Boot 2022.10-stm32mp-r1 (Oct 03 2022 - 19:25:32 +0000)
Board: stm32mp1 in trusted mode (st,stm32mp157f-ev1)
DRAM:  1 GiB
Clocks:
- MPU : 800 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
stmfx stmfx@42: STMFX id: 0x7b, fw version: 3.03
Core:  377 devices, 45 uclasses, devicetree: board
WDT:   Started watchdog with servicing (32s timeout)
NAND:  1024 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:8...
Found /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
Retrieving file: /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
Retrieving file: /splash_portrait.bmp
Select the boot mode
1:      OpenSTLinux
2:      stm32mp157f-ev1-a7-examples
3:      stm32mp157f-ev1-m4-examples
Retrieving file: /uImage
Retrieving file: /st-image-resize-initrd
append: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw   console=ttySTM0,115200
Retrieving file: /stm32mp157f-ev1.dtb
   Image Name:   Linux-6.1.28
   Created:      2023-05-11  14:04:52 UTC
   Data Size:    8213192 Bytes = 7.8 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image
   Loading Ramdisk to cfa0c000, end cffffcd7 ... OK
   Loading Device Tree to cf9e8000, end cfa0b9cc ... OK
Starting kernel ...
I/TC: Secondary CI/TC: Secondary CPU 1 switching to normal world boot
[    0.000000] Linux version 6.1.28 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.40.20230119) #1 SMP PREEMPT Thu May 11 14:04:52 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157F eval daughter on eval mother
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0xf5800000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10048000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcu-rsc-table@10048000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000c0000000-0x00000000e7ffffff]
[    0.000000]   HighMem  [mem 0x00000000e8000000-0x00000000ffffefff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000e7ffffff]
[    0.000000]   node   0: [mem 0x00000000e8000000-0x00000000efffffff]
[    0.000000]   node   0: [mem 0x00000000f0000000-0x00000000fdbfffff]
[    0.000000]   node   0: [mem 0x00000000fdc00000-0x00000000fdfeffff]
[    0.000000]   node   0: [mem 0x00000000fdff0000-0x00000000fdffffff]
[    0.000000]   node   0: [mem 0x00000000fe000000-0x00000000ffffefff]
[    0.000000] Initmem setup node 0 [mem 0x00000000c0000000-0x00000000ffffefff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 17 pages/cpu s38228 r8192 d23212 u69632
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260703
[    0.000000] Kernel command line: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw   console=ttySTM0,115200
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] Memory: 713816K/1048572K available (12288K kernel code, 1371K rwdata, 3636K rodata, 1024K init, 235K bss, 203684K reserved, 131072K cma-reserved, 94272K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000020] Switching to timer-based delay loop, resolution 41ns
[    0.001778] Console: colour dummy device 80x30
[    0.001848] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001870] pid_max: default: 32768 minimum: 301
[    0.002183] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002211] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.003429] CPU: Testing write buffer coherency: ok
[    0.004000] /cpus/cpu@0 missing clock-frequency property
[    0.004051] /cpus/cpu@1 missing clock-frequency property
[    0.004071] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005668] cblist_init_generic: Setting adjustable number of callback queues.
[    0.005688] cblist_init_generic: Setting shift to 1 and lim to 1.
[    0.005891] cblist_init_generic: Setting shift to 1 and lim to 1.
[    0.006110] Setting up static identity map for 0xc0100000 - 0xc0100060
[    0.006383] rcu: Hierarchical SRCU implementation.
[    0.006393] rcu:     Max phase no-delay instances is 1000.
[    0.008177] smp: Bringing up secondary CPUs ...
[    0.016016] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.016239] smp: Brought up 1 node, 2 CPUs
[    0.016257] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.016269] CPU: All CPU(s) started in SVC mode.
[    0.017314] devtmpfs: initialized
[    0.057060] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.057450] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.057488] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.063877] pinctrl core: initialized pinctrl subsystem
[    0.066462] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.069279] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.071109] thermal_sys: Registered thermal governor 'step_wise'
[    0.071604] cpuidle: using governor menu
[    0.072038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.072060] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.072483] Serial: AMBA PL011 UART driver
[    0.076620] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[    0.076665] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[    0.076677] stm32-pm-domain pm_domain: domains probed
[    0.110206] platform 5a001000.display-controller: Fixed dependency cycle(s) with /soc/dsi@5a000000
[    0.118556] platform 4c006000.dcmi: Fixed dependency cycle(s) with /soc/etzpc@5c007000/i2c@40013000/camera@3c
[    0.132397] platform dmic-0: Fixed dependency cycle(s) with /soc/etzpc@5c007000/dfsdm@4400d000/filter@0/dfsdm-dai
[    0.132800] platform dmic-1: Fixed dependency cycle(s) with /soc/etzpc@5c007000/dfsdm@4400d000/filter@1/dfsdm-dai
[    0.133166] platform dmic-2: Fixed dependency cycle(s) with /soc/etzpc@5c007000/dfsdm@4400d000/filter@2/dfsdm-dai
[    0.133606] platform dmic-3: Fixed dependency cycle(s) with /soc/etzpc@5c007000/dfsdm@4400d000/filter@3/dfsdm-dai
[    0.135018] platform 4000d000.audio-controller: Fixed dependency cycle(s) with /spdif-in
[    0.135634] platform spdif-out: Fixed dependency cycle(s) with /soc/etzpc@5c007000/sai@50027000/audio-controller@50027004
[    0.150758] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.164427] SCSI subsystem initialized
[    0.165453] usbcore: registered new interface driver usbfs
[    0.165525] usbcore: registered new interface driver hub
[    0.165587] usbcore: registered new device driver usb
[    0.166155] pps_core: LinuxPPS API ver. 1 registered
[    0.166167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.166194] PTP clock support registered
[    0.166504] EDAC MC: Ver: 3.0.0
[    0.167889] Driver 'scmi-optee' was unable to register with bus_type 'tee' because the bus was not initialized.
[    0.171218] clocksource: Switched to clocksource arch_sys_counter
[    0.186999] NET: Registered PF_INET protocol family
[    0.187428] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.191049] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.191100] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.191130] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.191279] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.191549] TCP: Hash tables configured (established 8192 bind 8192)
[    0.191748] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.191822] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.192245] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.193430] RPC: Registered named UNIX socket transport module.
[    0.193451] RPC: Registered udp transport module.
[    0.193458] RPC: Registered tcp transport module.
[    0.193463] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.194266] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.194686] Trying to unpack rootfs image as initramfs...
[    0.196437] Initialise system trusted keyrings
[    0.201547] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.222970] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.242251] NFS: Registering the id_resolver key type
[    0.242368] Key type id_resolver registered
[    0.242380] Key type id_legacy registered
[    0.242571] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.242588] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.242777] ntfs: driver 2.1.32 [Flags: R/O].
[    0.243097] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.243904] fuse: init (API version 7.37)
[    0.245119] NET: Registered PF_ALG protocol family
[    0.245148] Key type asymmetric registered
[    0.245157] Asymmetric key parser 'x509' registered
[    0.245438] bounce: pool size: 64 pages
[    0.245654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.245672] io scheduler mq-deadline registered
[    0.245682] io scheduler kyber registered
[    0.264613] STM32 USART driver initialized
[    0.307203] brd: module loaded
[    0.325965] loop: module loaded
[    0.334252] CAN device driver interface
[    0.336839] pegasus: Pegasus/Pegasus II USB Ethernet driver
[    0.336920] usbcore: registered new interface driver pegasus
[    0.336988] usbcore: registered new interface driver asix
[    0.337037] usbcore: registered new interface driver ax88179_178a
[    0.337106] usbcore: registered new interface driver cdc_ether
[    0.337185] usbcore: registered new interface driver smsc75xx
[    0.337260] usbcore: registered new interface driver smsc95xx
[    0.337311] usbcore: registered new interface driver net1080
[    0.337361] usbcore: registered new interface driver cdc_subset
[    0.337409] usbcore: registered new interface driver zaurus
[    0.337523] usbcore: registered new interface driver cdc_ncm
[    0.352584] usbcore: registered new interface driver usb-storage
[    0.352908] usbcore: registered new device driver onboard-usb-hub
[    0.363457] i2c_dev: i2c /dev entries driver
[    0.381822] arm_smc_wdt watchdog: Watchdog registered (timeout=32 sec, nowayout=0)
[    0.384482] sdhci: Secure Digital Host Controller Interface driver
[    0.384499] sdhci: Copyright(c) Pierre Ossman
[    0.384506] Synopsys Designware Multimedia Card Interface Driver
[    0.385039] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.386554] ledtrig-cpu: registered to indicate activity on CPUs
[    0.387129] usbcore: registered new interface driver usbhid
[    0.387143] usbhid: USB HID core driver
[    0.389906] optee: probing for conduit method.
[    0.389937] optee: revision 3.19 (afacf356)
[    0.390546] optee: dynamic shared memory is enabled
[    0.402013] optee: initialized driver
[    0.405006] NET: Registered PF_PACKET protocol family
[    0.405031] can: controller area network core
[    0.405138] NET: Registered PF_CAN protocol family
[    0.405150] can: raw protocol
[    0.405162] can: broadcast manager protocol
[    0.405178] can: netlink gateway - max_hops=1
[    0.405918] random: crng init done
[    0.411817] Key type dns_resolver registered
[    0.411947] ThumbEE CPU extension supported.
[    0.411973] Registering SWP/SWPB emulation handler
[    0.412604] registered taskstats version 1
[    0.412668] Loading compiled-in X.509 certificates
[    0.663886] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.664127] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.664222] arm-scmi firmware:scmi: SCMI Protocol v2.0 'ST:' Firmware version 0x0
[    0.771331] stm32-dma 48000000.dma-controller: STM32 DMA driver registered
[    0.773828] stm32-dma 48001000.dma-controller: STM32 DMA driver registered
[    0.791296] stm32-mdma 58000000.dma-controller: STM32 MDMA driver registered
[    0.795891] [drm] Initialized simpledrm 1.0.0 20200625 for fdc00000.framebuffer on minor 0
[    0.821818] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[    0.827063] /soc/interrupt-controller@5000d000: bank0
[    0.827110] /soc/interrupt-controller@5000d000: bank1
[    0.827128] /soc/interrupt-controller@5000d000: bank2
[    0.841828] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOA bank added
[    0.842709] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOB bank added
[    0.843563] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOC bank added
[    0.844361] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOD bank added
[    0.845221] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOE bank added
[    0.846092] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOF bank added
[    0.846972] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOG bank added
[    0.861718] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOH bank added
[    0.862717] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOI bank added
[    0.863636] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOJ bank added
[    0.864449] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOK bank added
[    0.864988] stm32mp157-pinctrl soc:pinctrl@50002000: Pinctrl STM32 initialized
[    0.871892] stm32mp157-pinctrl soc:pinctrl@54004000: GPIOZ bank added
[    0.871948] stm32mp157-pinctrl soc:pinctrl@54004000: Pinctrl STM32 initialized
[    0.874671] Freeing initrd memory: 6096K
[    0.875415] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[    0.875433] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[    0.875461] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 49, base_baud = 4000000) is a stm32-usart
[    2.241102] printk: console [ttySTM0] enabled
[    2.258302] spi-nor spi0.0: mx66l51235f (65536 Kbytes)
[    2.262309] 8 fixed-partitions partitions found on MTD device spi0.0
[    2.268399] Creating 8 MTD partitions on "spi0.0":
[    2.273193] 0x000000000000-0x000000040000 : "fsbl1"
[    2.280302] 0x000000040000-0x000000080000 : "fsbl2"
[    2.285938] 0x000000080000-0x0000000c0000 : "metadata1"
[    2.291923] 0x0000000c0000-0x000000100000 : "metadata2"
[    2.297921] 0x000000100000-0x000000500000 : "fip-a"
[    2.303552] 0x000000500000-0x000000900000 : "fip-b"
[    2.309158] 0x000000900000-0x000000980000 : "u-boot-env"
[    2.315378] 0x000000980000-0x000004000000 : "nor-user"
[    2.322335] spi-nor spi0.1: mx66l51235f (65536 Kbytes)
[    2.330669] m_can_platform 4400e000.can: m_can device registered (irq=51, version=32)
[    2.339161] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[    2.344768] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[    2.350769] stm32-dwmac 5800a000.ethernet:   DWMAC4/5
[    2.355798] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[    2.363016] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[    2.370289] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[    2.377179] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[    2.383588] stm32-dwmac 5800a000.ethernet: TSO supported
[    2.388749] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.396661] stm32-dwmac 5800a000.ethernet: Enabled L3L4 Flow TC (entries=2)
[    2.403557] stm32-dwmac 5800a000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.410531] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[    2.416427] stm32-dwmac 5800a000.ethernet: Using 32/32 bits DMA host/device width
[    2.436532] stm32_rtc 5c004000.rtc: registered as rtc0
[    2.440343] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:32:32 UTC (946686752)
[    2.449451] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[    2.455125] stm32_rtc 5c004000.rtc: registered rev:1.2
[    2.478200] i2c 0-001b: Fixed dependency cycle(s) with /soc/etzpc@5c007000/sai@4400b000/audio-controller@4400b024
[    2.487190] i2c 0-001b: Fixed dependency cycle(s) with /soc/etzpc@5c007000/sai@4400b000/audio-controller@4400b004
[    2.499091] stm32f7-i2c 40013000.i2c: STM32F7 I2C-0 bus adapter
[    2.521754] stm32f7-i2c 40015000.i2c: STM32F7 I2C-1 bus adapter
[    2.547615] stpmic1 2-0033: PMIC Chip Version: 0x20
[    2.586240] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.595266] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.605402] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.615728] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.625952] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.636306] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.646532] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.656756] stpmic1-regulator 5c002000.i2c:stpmic@33:regulators: Failed to create device link (0x180) with 2-0033
[    2.667489] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-2 bus adapter
[    2.677048] mmci-pl18x 58005000.mmc: Got CD GPIO
[    2.681898] mmci-pl18x 58005000.mmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 70,0 (pio)
[    2.723993] mmci-pl18x 58007000.mmc: mmc1: PL180 manf 53 rev2 at 0x58007000 irq 72,0 (pio)
[    2.768903] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[    2.778000] stm32-rproc 10000000.m4: wdg irq registered
[    2.783587] remoteproc remoteproc0: m4 is available
[    2.793310] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xd3
[    2.800372] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[    2.805601] nand: Micron MT29F8G08ABACAH4
[    2.809450] nand: 1024 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224
[    2.818491] Bad block table found at page 262080, version 0x01
[    2.818640] mmcblk0: mmc0:5048 SD32G 29.0 GiB
[    2.825652] Bad block table found at page 262016, version 0x01
[    2.834104] 9 fixed-partitions partitions found on MTD device 80000000.nand-controller
[    2.842595] Creating 9 MTD partitions on "80000000.nand-controller":
[    2.847838] 0x000000000000-0x000000080000 : "fsbl1"
[    2.855423] 0x000000080000-0x000000100000 : "fsbl2"
[    2.861930]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    2.862125] 0x000000100000-0x000000180000 : "metadata1"
[    2.875115] 0x000000180000-0x000000200000 : "metadata2"
[    2.881276] 0x000000200000-0x000000600000 : "fip-a1"
[    2.891553] 0x000000600000-0x000000a00000 : "fip-a2"
[    2.892365] mmc1: new DDR MMC card at address 0001
[    2.897235] 0x000000a00000-0x000000e00000 : "fip-b1"
[    2.901370] mmcblk1: mmc1:0001 004GA0 3.69 GiB
[    2.907263] 0x000000e00000-0x000001200000 : "fip-b2"
[    2.913451] mmcblk1boot0: mmc1:0001 004GA0 2.00 MiB
[    2.916756] 0x000001200000-0x000040000000 : "UBI"
[    2.922244] mmcblk1boot1: mmc1:0001 004GA0 2.00 MiB
[    2.932366] mmcblk1rpmb: mmc1:0001 004GA0 512 KiB, chardev (244:0)
[    2.939217] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[    2.949686] stmfx-core 0-0042: STMFX id: 0x7b, fw version: 3.03
[    2.989391] stmfx-pinctrl stmfx-pinctrl: 24 GPIOs available
[    3.004532] Goodix-TS 0-005d: supply AVDD28 not found, using dummy regulator
[    3.010555] Goodix-TS 0-005d: supply VDDIO not found, using dummy regulator
[    3.019820] Goodix-TS 0-005d: ID 9147, version: 1040
[    3.044846] input: Goodix Capacitive TouchScreen as /devices/platform/soc/5c007000.etzpc/40013000.i2c/i2c-0/0-005d/input/input0
[    3.061987] input: pmic_onkey as /devices/platform/soc/5c007000.etzpc/5c002000.i2c/i2c-2/2-0033/5c002000.i2c:stpmic@33:onkey/input/input2
[    3.076358] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[    3.083789] dwc2 49000000.usb-otg: supply vusb_d not found, using dummy regulator
[    3.090196] dwc2 49000000.usb-otg: supply vusb_a not found, using dummy regulator
[    3.091553] ehci-platform 5800d000.usb: EHCI Host Controller
[    3.103130] ehci-platform 5800d000.usb: new USB bus registered, assigned bus number 1
[    3.111924] ehci-platform 5800d000.usb: irq 91, io mem 0x5800d000
[    3.141650] ehci-platform 5800d000.usb: USB 2.0 started, EHCI 1.00
[    3.149253] hub 1-0:1.0: USB hub found
[    3.152012] hub 1-0:1.0: 2 ports detected
[    3.229004] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[    3.236713] dwc2 49000000.usb-otg: DWC OTG Controller
[    3.240487] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 2
[    3.247974] dwc2 49000000.usb-otg: irq 92, io mem 0x49000000
[    3.255620] hub 2-0:1.0: USB hub found
[    3.258416] hub 2-0:1.0: 1 port detected
[    3.290347] input: joystick as /devices/platform/joystick/input/input3
[    3.302659] Freeing unused kernel image (initmem) memory: 1024K
[    3.341974] Run /init as init process
[    3.441386] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    3.642980] hub 1-1:1.0: USB hub found
[    3.645574] hub 1-1:1.0: 4 ports detected
Starting systemd-udevd version 253.1^
[    5.185685] mtdblock: MTD device 'fsbl2' is NAND, please consider using UBI block devices instead.
[    5.195927] mtdblock: MTD device 'metadata1' is NAND, please consider using UBI block devices instead.
[    5.213021] mtdblock: MTD device 'metadata2' is NAND, please consider using UBI block devices instead.
[    5.233719] mtdblock: MTD device 'fip-a1' is NAND, please consider using UBI block devices instead.
[    5.261855] mtdblock: MTD device 'fip-b1' is NAND, please consider using UBI block devices instead.
[    5.272140] mtdblock: MTD device 'fip-a2' is NAND, please consider using UBI block devices instead.
[    5.285864] mtdblock: MTD device 'fip-b2' is NAND, please consider using UBI block devices instead.
[    5.314926] mtdblock: MTD device 'UBI' is NAND, please consider using UBI block devices instead.
[    5.335636] mtdblock: MTD device 'fsbl1' is NAND, please consider using UBI block devices instead.
[    5.592410] stm32-dwmac 5800a000.ethernet end0: renamed from eth0
[    6.134771] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Quota mode: disabled.
ln: /etc/mtab: File exists
[    6.752943] systemd[1]: System time before build time, advancing clock.
[    6.873132] NET: Registered PF_INET6 protocol family
[    6.936055] Segment Routing with IPv6
[    6.938395] In-situ OAM (IOAM) with IPv6
[    6.994314] systemd[1]: systemd 253.1^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK -SECCOMP -GCRYPT -GNUTLS -OPENSSL -ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP)
[    7.024944] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21 (mickledore)!
[    7.224620] systemd[1]: Hostname set to <stm32mp1>.
[    7.326309] systemd[1]: Using hardware watchdog 'arm_smc_wdt', version 0, device /dev/watchdog0
[    7.333894] systemd[1]: Watchdog running with a timeout of 32s.
[    8.221280] systemd[1]: /lib/systemd/system/mount-partitions.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    8.260746] systemd[1]: Queued start job for default target Multi-User System.
[    8.382194] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    8.428633] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    8.468892] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    8.504683] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    8.542737] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    8.582590] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    8.622943] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    8.662003] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    8.701975] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    8.742055] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    8.875110] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    8.912252] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    8.954105] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    9.018059] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    9.053615] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    9.110976] systemd[1]: Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
[    9.122073] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    9.164065] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    9.204217] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    9.244389] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    9.283527] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    9.323641] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    9.363849] systemd[1]: Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    9.432955] systemd[1]: Mounting POSIX Message Queue File System...
[    9.482252] systemd[1]: Mounting Kernel Debug File System...
[    9.531747] systemd[1]: Mounting Kernel Trace File System...
[    9.589570] systemd[1]: Mounting Temporary Directory /tmp...
[    9.684083] systemd[1]: Starting Create List of Static Device Nodes...
[    9.738284] systemd[1]: Starting Load Kernel Module configfs...
[    9.787162] systemd[1]: Starting Load Kernel Module drm...
[    9.830672] systemd[1]: Starting Load Kernel Module fuse...
[    9.886988] systemd[1]: Starting Mount partitions...
[    9.982965] systemd[1]: Starting RPC Bind...
[   10.012471] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   10.038434] systemd[1]: Starting Journal Service...
[   10.055223] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
[   10.080447] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[   10.159154] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.174566] systemd-journald[292]: Collecting audit messages is disabled.
[   10.242478] systemd[1]: Starting Apply Kernel Variables...
[   10.341396] EXT4-fs (mmcblk0p10): re-mounted. Quota mode: disabled.
[   10.358929] systemd[1]: Starting Coldplug All udev Devices...
[   10.479740] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[   10.494193] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[   10.509748] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[   10.522783] systemd[1]: Mounted Kernel Trace File System.
[  OK  ] Mounted Kernel Trace File System.
[   10.562708] systemd[1]: Mounted Temporary Directory /tmp.
[  OK  ] Mounted Temporary Directory /tmp.
[   10.587021] systemd[1]: Finished Create List of Static Device Nodes.
[  OK  ] Finished Create List of Static Device Nodes.
[   10.630229] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Quota mode: disabled.
[   10.690518] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.713829] systemd[1]: Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module configfs.
[   10.733234] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Apply Kernel Variables.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Starts Psplash Boot screen...
         Starting Flush Journal to Persistent Storage...
[   11.176734] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Quota mode: disabled.
         Starting Create Static Device Nodes in /dev...
[   11.362235] systemd-journald[292]: Received client request to flush runtime journal.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
[   11.616905] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Quota mode: disabled.
         Mounting /var/volatile...
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Mount partitions.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Name Resolution...
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[   13.150487] mtdblock: MTD device 'fsbl2' is NAND, please consider using UBI block devices instead.
[   13.172225] mtdblock: MTD device 'metadata1' is NAND, please consider using UBI block devices instead.
[   13.187899] mtdblock: MTD device 'fip-b2' is NAND, please consider using UBI block devices instead.
[   13.187899] mtdblock: MTD device 'metadata2' is NAND, please consider using UBI block devices instead.
[   13.303996] mtdblock: MTD device 'fip-a2' is NAND, please consider using UBI block devices instead.
[   13.470804] mtdblock: MTD device 'fip-a1' is NAND, please consider using UBI block devices instead.
[   13.488406] mtdblock: MTD device 'fip-b1' is NAND, please consider using UBI block devices instead.
[   13.568236] mtdblock: MTD device 'UBI' is NAND, please consider using UBI block devices instead.
[   13.621933] mtdblock: MTD device 'fsbl1' is NAND, please consider using UBI block devices instead.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Finished Coldplug All udev Devices.
[   15.494707] stm32-crc32 58009000.crc: Initialized
[   15.619501] galcore: loading out-of-tree module taints kernel.
[   15.637223] st,stm32-spdifrx 4000d000.audio-controller: No cache defaults, reading back from HW
[   15.673691] wm8994 0-001b: supply DCVDD not found, using dummy regulator
[   15.679449] wm8994 0-001b: supply AVDD1 not found, using dummy regulator
[   15.693826] mc: Linux media interface: v0.10
[   15.757893] Galcore version 6.4.13.608341
[   15.783293] videodev: Linux video capture interface: v2.00
[   15.851008] stm32-dfsdm 4400d000.dfsdm: SPI clock not accurate
[   15.867186] stm32-dfsdm 4400d000.dfsdm: 24573875 = 2048000 * 12 + 2045875
[   16.036235] stm32-cryp 54001000.cryp: will run requests pump with realtime priority
[   16.061344] stm32-dcmi 4c006000.dcmi: Probe done
[   16.065651] stm32-hash 54002000.hash: will run requests pump with realtime priority
[   16.086276] ov5640 0-003c: supply AVDD not found, using dummy regulator
[   16.087221] wm8994 0-001b: WM8994 revision D CUST_ID 00
[   16.092025] ov5640 0-003c: supply DVDD not found, using dummy regulator
[   16.105918] wm8994 0-001b: No interrupt specified, no interrupts
[   16.166239] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[   16.189839] stm32-cryp 54001000.cryp: Initialized
[   16.255009] ov5640 0-003c: Consider updating driver ov5640 to match on endpoints
[*     ] A start job is running for Starts Psplash Boot screen (8s / no limit)
[   17.437945] using random self ethernet address
[   17.441034] using random host ethernet address
[   17.572774] usb0: HOST MAC a8:72:8d:68:fe:3c
[   17.575664] usb0: MAC 9a:d2:a6:32:49:45
[   17.586135] dwc2 49000000.usb-otg: bound driver configfs-gadget.g1
[   17.728824] dwc2 49000000.usb-otg: new device is high-speed
[**    ] A start job is running for Starts Psplash Boot screen (9s / no limit)
[   17.991109] dwc2 49000000.usb-otg: new device is high-speed
[   18.040907] dwc2 49000000.usb-otg: new device is high-speed
[   18.080064] dwc2 49000000.usb-otg: new address 29
[   18.134477] wm8994-codec wm8994-codec: Failed to request Mic1 detect IRQ: -22
[   18.140283] wm8994-codec wm8994-codec: Failed to request Mic1 short IRQ: -22
[   18.154564] wm8994-codec wm8994-codec: Failed to request Mic2 detect IRQ: -22
[***   ] A start job is running for Starts Psplash Boot screen (9s / no limit)
[   18.239205] dwc2 49000000.usb-otg: new device is high-speed
[   18.288890] dwc2 49000000.usb-otg: new device is high-speed
[   18.328206] dwc2 49000000.usb-otg: new address 29
[  OK  ] Created slice Slice /system/systemd-backlight.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Load/Save Screen …f backlight:panel-backlight...
[  OK  ] Finished Load/Save Screen … of backlight:panel-backlight.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Serves stm32mp clocks calibration..
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Socket Units.
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Basic System.
         Starting ST set alsa state configuration...
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started Calibrates HSI/CSI clocks.
         Starting Resets System Activity Logs...
         Starting User Login Management...
         Starting TEE Supplicant...
         Starting Check if the gpu …orrect weston configuration...
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Resets System Activity Logs.
[  OK  ] Started TEE Supplicant.
[  OK  ] Finished ST set alsa state configuration.
[  OK  ] Reached target Preparation for Network.
         Starting Save/Restore Sound Card State...
         Starting Network Configuration...
[  OK  ] Finished Check if the gpu … correct weston configuration.
[  OK  ] Started User Login Management.
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Reached target Sound Card.
[   21.642802] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   21.677613] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  OK  ] Started Network Configuration.
[   21.824642] stm32-dwmac 5800a000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   21.838276] stm32-dwmac 5800a000.ethernet end0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[  OK  ] Reached target Ne[   21.851531] dwmac4: Master AXI performs any burst length
[   21.856335] stm32-dwmac 5800a000.ethernet end0: No Safety Features support found
[   21.863918] stm32-dwmac 5800a000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[   21.872555] stm32-dwmac 5800a000.ethernet end0: registered PTP clock
twork   21.879506] stm32-dwmac 5800a000.ethernet end0: configuring for phy/rgmii-id link mode
m.
[  OK  ] Started IIO Daemon.
         Starting Real time performance monitoring...
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Target Communication Framework agent.
[  OK  ] Started Real time performance monitoring.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Reached target Login Prompts.
         Starting Weston graphical session...
         Starting User Database Manager...
[  OK  ] Started User Database Manager.
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston.
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21 stm32mp1 ttySTM0
root@stm32mp1:~#
3. Basic commands[edit | edit source]
3.1. Printing distribution specific information[edit | edit source]
root@stm32mp1:~# cat /etc/build
Build Configuration:  |
BB_VERSION = 2.4.0
BUILD_SYS = x86_64-linux
NATIVELSBSTRING = universal
MACHINE = stm32mp1
DISTRO = openstlinux-weston
DISTRO_VERSION = 4.2.1-openstlinux-6.1-yocto-mickledore-mp1-v23.06.21
TARGET_FPU = hard
MANIFESTVERSION = ostl-23-04-26-rc7-2-gebc8636
DISTRO_CODENAME = mickledore
ACCEPT_EULA_stm32mp1 = 1
GCCVERSION = 12.%
Layer Revisions:      |
meta-python       = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-oe           = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-gnome        = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-initramfs    = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-multimedia   = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-networking   = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-webserver    = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-filesystems  = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-perl         = v5.0.xml:c032fd0b1a9d444711103c2703dfa8e2964a3865
meta-st-stm32mp   = v5.0.xml:c8e93ac4745c841e4d87f49a63029920eeabec39
meta-qt5          = v5.0.xml:cf6ffcbad5275a3428f6046468a0c9d572e813d1
meta-st-openstlinux = v5.0.xml:a797f79a645c32e5c3b3d2eb1922f80b949d299b
meta              = v5.0.xml:20cd64812d286c920bd766145ab1cd968e72667e
3.2. Printing system information[edit | edit source]
root@stm32mp1:~# uname -a
Linux stm32mp1 6.1.28 #1 SMP PREEMPT Thu May 11 14:04:52 UTC 2023 armv7l GNU/Linux
3.3. Printing Linux kernel and GCC versions[edit | edit source]
root@stm32mp1:~# cat /proc/version
3.4. Printing the amount of disk space available on all mounted file systems[edit | edit source]
root@stm32mp1:~# df -h
Filesystem       Size  Used Avail Use% Mounted on
devtmpfs         349M     0  349M   0% /dev
/dev/mmcblk0p10  3.8G  454M  3.2G  13% /
tmpfs            417M     0  417M   0% /dev/shm
tmpfs            167M  9.0M  158M   6% /run
tmpfs            4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs            417M  8.0K  417M   1% /tmp
/dev/mmcblk0p8    55M   17M   34M  33% /boot
/dev/mmcblk0p9    14M  6.3M  6.4M  50% /vendor
/dev/mmcblk0p11   24G   43M   23G   1% /usr/local
tmpfs            417M   80K  416M   1% /var/volatile
tmpfs             84M  4.0K   84M   1% /run/user/1000
tmpfs             84M     0   84M   0% /run/user/0
3.5. ssh connection (only if the Ethernet cable is connected)[edit | edit source]
 ip addr show eth0
  • On the host computer, connect the terminal to the board using ssh
 ssh root@xx.xx.xx.xx
root@stm32mp1:~#
