This step explains how to connect your host Linux® terminal to your host computer through the ST-LINK/V2-1.
It then describes how to execute basic commands with the Linux command line interface in order to order to get familiar with the Linux console.
2. Serial terminal[edit | edit source]
The serial terminal allows communicating with the board through an UART serial interface.
  • Install minicom
PC $> sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
PC $> ls /dev/ttyACM*
/dev/ttyACM0
PC $> minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z for help on special keys
  • Press the reset button to reset the board. The boot log should be displayed on the minicom window:
For ecosystem release v3.1.0 More info.png :
NOTICE:  Model: STMicroelectronics STM32MP157F eval daughter on eval mother
NOTICE:  Board: MB1263 Var4.0 Rev.C-03
INFO:    Reset reason (0x14):
INFO:    PMIC version = 0x20
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:    FCONF: Reading firmware configuration information for: stm32mp_io
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.4-r2.0(debug):v2.4-dirty
NOTICE:  BL2: Built : 16:43:51, Nov 17 2020
INFO:    RAM: DDR3-DDR3L 32bits 533000kHz
INFO:    Memory size = 0x40000000 (1024 MB)
INFO:    BL2: Loading image id 31
INFO:    Loading image id=31 at address 0x2ffff000
INFO:    Image id=31 loaded: 0x2ffff000 - 0x2ffff226
INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
INFO:    FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO:    Loading image id=4 at address 0x2ffc5000
INFO:    Image id=4 loaded: 0x2ffc5000 - 0x2ffd97ec
WARNING: Not a known TEE, use default loading options.
INFO:    BL2: Skip loading image id 21
INFO:    BL2: Skip loading image id 22
INFO:    BL2: Loading image id 23
INFO:    Loading image id=23 at address 0xc0500000
INFO:    Image id=23 loaded: 0xc0500000 - 0xc051ebf6
INFO:    BL2: Loading image id 26
INFO:    Loading image id=26 at address 0x2ffc0000
INFO:    Image id=26 loaded: 0x2ffc0000 - 0x2ffc47e1
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01d3ee8
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0x2ffc5000
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.4-r2.0(debug):v2.4-dirty
NOTICE:  SP_MIN: Built : 16:43:51, Nov 17 2020
INFO:    ARM GICv2 driver initialized
INFO:    Set calibration timer to 60 sec
INFO:    stm32mp1 IWDG1 is secure
INFO:    SP_MIN: Initializing runtime services
INFO:    SP_MIN: Preparing exit to normal world
U-Boot 2020.10-stm32mp-r2 (Oct 05 2020 - 15:15:32 +0000)
CPU: STM32MP157FAA Rev.Z
Board: stm32mp1 in trusted mode (st,stm32mp157f-ev1)
DRAM:  1 GiB
Clocks:
- MPU : 800 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  1024 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:4...
Found /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
Retrieving file: /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
769 bytes read in 35 ms (20.5 KiB/s)
Retrieving file: /splash_portrait.bmp
89462 bytes read in 38 ms (2.2 MiB/s)
Select the boot mode
1:      OpenSTLinux
2:      stm32mp157f-ev1-a7-examples
3:      stm32mp157f-ev1-m4-examples
Retrieving file: /st-image-resize-initrd
3635706 bytes read in 188 ms (18.4 MiB/s)
Retrieving file: /uImage
7464336 bytes read in 350 ms (20.3 MiB/s)
append: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw    console=ttySTM0,115200
Retrieving file: /stm32mp157f-ev1.dtb
123279 bytes read in 40 ms (2.9 MiB/s)
   Image Name:   Linux-5.10.61
   Created:      2021-08-26  12:51:21 UTC
   Data Size:    7464272 Bytes = 7.1 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image
   Loading Ramdisk to cfc88000, end cffff9fa ... OK
   Loading Device Tree to cfc66000, end cfc8718e ... OK
Starting kernel ...
[    0.000000] Linux version 5.10.61 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34.0.20200220) #1 SMP PREEMPT Thu Aug 26 12:51:21 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157F eval daughter on eval mother
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10048000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcu_rsc_table@10048000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 128 MiB at 0xe8000000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000c0000000-0x00000000efffffff]
[    0.000000]   HighMem  [mem 0x00000000f0000000-0x00000000ffffefff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000f5cfffff]
[    0.000000]   node   0: [mem 0x00000000f5d00000-0x00000000f5feffff]
[    0.000000]   node   0: [mem 0x00000000f5ff0000-0x00000000f5ffffff]
[    0.000000]   node   0: [mem 0x00000000f6000000-0x00000000fdffffff]
[    0.000000]   node   0: [mem 0x00000000fe000000-0x00000000ffffefff]
[    0.000000] Initmem setup node 0 [mem 0x00000000c0000000-0x00000000ffffefff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 20 pages/cpu s51788 r8192 d21940 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260415
[    0.000000] Kernel command line: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw    console=ttySTM0,115200
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 751136K/1048572K available (11264K kernel code, 1207K rwdata, 3308K rodata, 1024K init, 239K bss, 166364K reserved, 131072K cma-reserved, 128060K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x388/0x560 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001484] Console: colour dummy device 80x30
[    0.001540] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001568] pid_max: default: 32768 minimum: 301
[    0.001797] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001822] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002973] CPU: Testing write buffer coherency: ok
[    0.003377] /cpus/cpu@0 missing clock-frequency property
[    0.003415] /cpus/cpu@1 missing clock-frequency property
[    0.003432] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004482] Setting up static identity map for 0xc0100000 - 0xc0100060
[    0.004665] rcu: Hierarchical SRCU implementation.
[    0.005880] smp: Bringing up secondary CPUs ...
[    0.006922] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.007144] smp: Brought up 1 node, 2 CPUs
[    0.007171] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.007182] CPU: All CPU(s) started in SVC mode.
[    0.007970] devtmpfs: initialized
[    0.039261] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.039661] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.039697] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.045634] pinctrl core: initialized pinctrl subsystem
[    0.047351] NET: Registered protocol family 16
[    0.050191] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.051822] thermal_sys: Registered thermal governor 'step_wise'
[    0.052218] cpuidle: using governor menu
[    0.052572] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.052589] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.052937] Serial: AMBA PL011 UART driver
[    0.103493] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[    0.103555] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[    0.103571] stm32-pm-domain pm_domain: domains probed
[    0.127391] SCSI subsystem initialized
[    0.128227] usbcore: registered new interface driver usbfs
[    0.128303] usbcore: registered new interface driver hub
[    0.128370] usbcore: registered new device driver usb
[    0.128666] pps_core: LinuxPPS API ver. 1 registered
[    0.128683] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.128715] PTP clock support registered
[    0.129543] arm-scmi firmware:scmi0: SCMI Notifications - Core Enabled.
[    0.129625] arm-scmi firmware:scmi0: SCMI Protocol v2.0 'ST:' Firmware version 0x0
[    0.132622] clocksource: Switched to clocksource arch_sys_counter
[    1.243928] simple-framebuffer f5d00000.framebuffer: framebuffer at 0xf5d00000, 0x1c2000 bytes, mapped to 0x(ptrval)
[    1.243962] simple-framebuffer f5d00000.framebuffer: format=r5g6b5, mode=720x1280x16, linelength=1440
[    1.244385] simple-framebuffer f5d00000.framebuffer: fb0: simplefb registered!
[    1.256306] NET: Registered protocol family 2
[    1.256591] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.258146] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.258293] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.258387] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.258529] TCP: Hash tables configured (established 8192 bind 8192)
[    1.258709] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.258794] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.259392] NET: Registered protocol family 1
[    1.260332] RPC: Registered named UNIX socket transport module.
[    1.260358] RPC: Registered udp transport module.
[    1.260369] RPC: Registered tcp transport module.
[    1.260380] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.260725] Trying to unpack rootfs image as initramfs...
[    1.559152] Freeing initrd memory: 3552K
[    1.559917] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.561760] Initialise system trusted keyrings
[    1.562143] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.570989] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.572261] NFS: Registering the id_resolver key type
[    1.572317] Key type id_resolver registered
[    1.572329] Key type id_legacy registered
[    1.572489] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.572506] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.572810] ntfs: driver 2.1.32 [Flags: R/O].
[    1.573116] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.573892] fuse: init (API version 7.32)
[    1.574816] NET: Registered protocol family 38
[    1.574841] Key type asymmetric registered
[    1.574854] Asymmetric key parser 'x509' registered
[    1.574931] bounce: pool size: 64 pages
[    1.574994] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.575010] io scheduler mq-deadline registered
[    1.575021] io scheduler kyber registered
[    1.587013] STM32 USART driver initialized
[    1.607561] brd: module loaded
[    1.610706] random: fast init done
[    1.615374] random: crng init done
[    1.619801] loop: module loaded
[    1.625704] libphy: Fixed MDIO Bus: probed
[    1.627467] CAN device driver interface
[    1.629652] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.629742] usbcore: registered new interface driver pegasus
[    1.629814] usbcore: registered new interface driver asix
[    1.629868] usbcore: registered new interface driver ax88179_178a
[    1.629919] usbcore: registered new interface driver cdc_ether
[    1.629986] usbcore: registered new interface driver smsc75xx
[    1.630065] usbcore: registered new interface driver smsc95xx
[    1.630118] usbcore: registered new interface driver net1080
[    1.630169] usbcore: registered new interface driver cdc_subset
[    1.630220] usbcore: registered new interface driver zaurus
[    1.630295] usbcore: registered new interface driver cdc_ncm
[    1.631495] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.631547] ehci-platform: EHCI generic platform driver
[    1.632038] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.632082] ohci-platform: OHCI generic platform driver
[    1.633074] usbcore: registered new interface driver usb-storage
[    1.637192] i2c /dev entries driver
[    1.641776] stm32-cpufreq stm32-cpufreq: Failed to get chip info: -517
[    1.643054] sdhci: Secure Digital Host Controller Interface driver
[    1.643073] sdhci: Copyright(c) Pierre Ossman
[    1.643084] Synopsys Designware Multimedia Card Interface Driver
[    1.643586] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.644902] ledtrig-cpu: registered to indicate activity on CPUs
[    1.645128] SMCCC: SOC_ID: ID = jep106:0020:0500 Revision = 0x00002001
[    1.645568] usbcore: registered new interface driver usbhid
[    1.645584] usbhid: USB HID core driver
[    1.647011] remoteproc remoteproc0: releasing m4
[    1.649573] NET: Registered protocol family 17
[    1.649618] can: controller area network core
[    1.649733] NET: Registered protocol family 29
[    1.649746] can: raw protocol
[    1.649761] can: broadcast manager protocol
[    1.649780] can: netlink gateway - max_hops=1
[    1.650485] Key type dns_resolver registered
[    1.650645] ThumbEE CPU extension supported.
[    1.650669] Registering SWP/SWPB emulation handler
[    1.651077] registered taskstats version 1
[    1.651105] Loading compiled-in X.509 certificates
[    1.687381] stm32-mdma 58000000.dma-controller: STM32 MDMA driver registered
[    1.691854] stm32-dma 48000000.dma-controller: STM32 DMA driver registered
[    1.694317] stm32-dma 48001000.dma-controller: STM32 DMA driver registered
[    1.703934] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[    1.709802] remoteproc remoteproc0: releasing m4
[    1.711204] /soc/interrupt-controller@5000d000: bank0
[    1.711233] /soc/interrupt-controller@5000d000: bank1
[    1.711249] /soc/interrupt-controller@5000d000: bank2
[    1.715609] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOA bank added
[    1.717987] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOB bank added
[    1.720321] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOC bank added
[    1.722591] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOD bank added
[    1.725037] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOE bank added
[    1.727312] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOF bank added
[    1.729580] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOG bank added
[    1.731843] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOH bank added
[    1.734242] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOI bank added
[    1.736570] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOJ bank added
[    1.738836] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOK bank added
[    1.739110] stm32mp157-pinctrl soc:pin-controller@50002000: Pinctrl STM32 initialized
[    1.742447] stm32mp157-pinctrl soc:pin-controller-z@54004000: GPIOZ bank added
[    1.742487] stm32mp157-pinctrl soc:pin-controller-z@54004000: Pinctrl STM32 initialized
[    1.746180] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[    1.746208] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[    1.746246] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 66, base_baud = 4000000) is a stm32-usart
[    2.995054] printk: console [ttySTM0] enabled
[    3.008307] spi-nor spi0.0: mx66l51235l (65536 Kbytes)
[    3.016912] spi-nor spi0.1: mx66l51235l (65536 Kbytes)
[    3.025143] m_can_platform 4400e000.can: m_can device registered (irq=62, version=32)
[    3.033449] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[    3.038253] stm32-dwmac 5800a000.ethernet: no reset control found
[    3.044864] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[    3.051050] stm32-dwmac 5800a000.ethernet:   DWMAC4/5
[    3.056070] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[    3.063380] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[    3.070650] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[    3.077538] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[    3.083950] stm32-dwmac 5800a000.ethernet: TSO supported
[    3.089108] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.096920] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[    3.103405] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[    3.109268] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[    3.117873] libphy: stmmac: probed
[    3.133938] stm32_rtc 5c004000.rtc: registered as rtc0
[    3.137762] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:41:13 UTC (946687273)
[    3.146790] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[    3.152460] stm32_rtc 5c004000.rtc: registered rev:1.2
[    3.184564] stm32f7-i2c 40013000.i2c: STM32F7 I2C-0 bus adapter
[    3.205665] stm32f7-i2c 40015000.i2c: STM32F7 I2C-1 bus adapter
[    3.231804] stpmic1 2-0033: PMIC Chip Version: 0x20
[    3.240961] vddcore: supplied by vin
[    3.246164] vdd_ddr: supplied by vin
[    3.251271] vdd: supplied by vin
[    3.256177] v3v3: supplied by vin
[    3.261226] vdda: supplied by v3v3
[    3.264688] v2v8: supplied by v3v3
[    3.267430] vtt_ddr: supplied by vdd_ddr
[    3.273722] vdd_usb: supplied by vin
[    3.276519] vdd_sd: supplied by v3v3
[    3.283016] v1v8: supplied by v3v3
[    3.285486] vref_ddr: supplied by vin
[    3.291885] bst_out: supplied by vin
[    3.294865] vbus_otg: supplied by bst_out
[    3.298780] vbus_sw: supplied by bst_out
[    3.305280] input: pmic_onkey as /devices/platform/soc/5c002000.i2c/i2c-2/2-0033/5c002000.i2c:stpmic@33:onkey/input/input0
[    3.315897] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-2 bus adapter
[    3.324082] mmci-pl18x 58005000.sdmmc: Got CD GPIO
[    3.328645] mmci-pl18x 58005000.sdmmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 57,0 (pio)
[    3.368789] mmci-pl18x 58007000.sdmmc: mmc1: PL180 manf 53 rev2 at 0x58007000 irq 58,0 (pio)
[    3.417507] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[    3.430343] stm32-rproc 10000000.m4: wdg irq registered
[    3.436218] remoteproc remoteproc0: m4 is available
[    3.446239] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[    3.453953] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xd3
[    3.459725] mmcblk0: mmc0:5048 SD32G 29.0 GiB
[    3.463551] nand: Micron MT29F8G08ABACAH4
[    3.467302] nand: 1024 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224
[    3.479006] Bad block table found at page 262080, version 0x01
[    3.484453] Bad block table found at page 262016, version 0x01
[    3.495427]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    3.501878] reg11: supplied by vdd
[    3.504429] reg18: supplied by vdd
[    3.508980] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[    3.520233] fb0: switching to stmdrmfb from simple
[    3.524674] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[    3.533593] dwc2 49000000.usb-otg: supply vusb_d not found, using dummy regulator
[    3.541000] dwc2 49000000.usb-otg: supply vusb_a not found, using dummy regulator
[    3.551443] mmc1: new DDR MMC card at address 0001
[    3.556227] mmcblk1: mmc1:0001 004GA0 3.69 GiB
[    3.559999] mmcblk1boot0: mmc1:0001 004GA0 partition 1 2.00 MiB
[    3.566097] mmcblk1boot1: mmc1:0001 004GA0 partition 2 2.00 MiB
[    3.571915] mmcblk1rpmb: mmc1:0001 004GA0 partition 3 512 KiB, chardev (243:0)
[    3.583913]  mmcblk1: p1 p2 p3 p4 p5
[    3.702848] usb33: supplied by vdd_usb
[    3.705833] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[    3.713835] dwc2 49000000.usb-otg: DWC OTG Controller
[    3.717687] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 1
[    3.725181] dwc2 49000000.usb-otg: irq 93, io mem 0x49000000
[    3.732659] hub 1-0:1.0: USB hub found
[    3.735112] hub 1-0:1.0: 1 port detected
[    3.741262] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[    3.746173] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 2
[    3.755345] ehci-platform 5800d000.usbh-ehci: irq 68, io mem 0x5800d000
[    3.782701] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[    3.790000] hub 2-0:1.0: USB hub found
[    3.792481] hub 2-0:1.0: 2 ports detected
[    3.801188] stmfx-core 0-0042: STMFX id: 0x7b, fw version: 3.03
[    3.836293] stmfx-pinctrl stmfx-pinctrl: DMA mask not set
[    3.844575] stmfx-pinctrl stmfx-pinctrl: 24 GPIOs available
[    3.857602] Goodix-TS 0-005d: supply AVDD28 not found, using dummy regulator
[    3.863752] Goodix-TS 0-005d: supply VDDIO not found, using dummy regulator
[    3.872026] Goodix-TS 0-005d: ID 9147, version: 1040
[    3.897270] input: Goodix Capacitive TouchScreen as /devices/platform/soc/40013000.i2c/i2c-0/0-005d/input/input1
[    3.936936] input: joystick as /devices/platform/joystick/input/input2
[    3.949238] Freeing unused kernel memory: 1024K
[    3.952999] Run /init as init process
[    4.082763] usb 2-1: new high-speed USB device number 2 using ehci-platform
Starting version 244.5+
[    4.284753] hub 2-1:1.0: USB hub found
[    4.287378] hub 2-1:1.0: 4 ports detected
[    5.638811] EXT4-fs (mmcblk0p6): recovery complete
[    5.643496] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    6.093187] systemd[1]: System time before build time, advancing clock.
[    6.222824] NET: Registered protocol family 10
[    6.254773] Segment Routing with IPv6
[    6.309459] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.330659] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17 (dunfell)!
[    6.425414] systemd[1]: Set hostname to <stm32mp1>.
[    6.438170] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', version 0
[    6.445566] systemd[1]: Set hardware watchdog to 32s.
[    7.183897] systemd[1]: Unnecessary job for /dev/ttySTM0 was removed.
[    7.196427] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    7.236967] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    7.274804] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    7.313895] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    7.353689] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    7.393604] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    7.423204] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.463085] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    7.493263] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    7.558363] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.593234] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.634659] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    7.694753] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.734477] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.782501] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.790812] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.824613] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.865283] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.904539] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.944089] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.984694] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.999312] systemd[1]: Mounting POSIX Message Queue File System...
[    8.040778] systemd[1]: Mounting Kernel Debug File System...
[    8.083212] systemd[1]: Mounting Temporary Directory (/tmp)...
[    8.135467] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    8.183445] systemd[1]: Starting Mount partitions...
[    8.232571] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    8.280306] systemd[1]: Starting RPC Bind...
[    8.313905] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.363569] systemd[1]: Starting Journal Service...
[    8.399842] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[    8.429033] systemd[1]: Mounting FUSE Control File System...
[    8.479048] systemd[1]: Mounting Kernel Configuration File System...
[    8.540590] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.616194] EXT4-fs (mmcblk0p4): recovery complete
[    8.619582] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    8.631918] systemd[1]: Starting Apply Kernel Variables...
[    8.679755] systemd[1]: Starting udev Coldplug all Devices...
[    8.694807] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    8.787301] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    8.801287] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    8.874866] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    8.914142] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[    8.952869] systemd[1]: Started Create list of static device nodes for the current kernel.
[  OK  ] Started Create list of sta… nodes for the current kernel.
[    8.994043] systemd[1]: Mounted FUSE Control File System.
[  OK  ] Mounted FUSE Control File System.
[    9.014174] systemd[1]: Mounted Kernel Configuration File System.
[  OK  ] Mounted Kernel Configuration File System.
[    9.049587] systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
[    9.104272] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Appl[    9.154462] EXT4-fs (mmcblk0p5): recovery complete
[    9.161238] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Starts Psplash Boot screen.
         Starting Flush Journal to Persistent Storage...
         Starting Create Static Device Nodes in /dev...
[    9.374924] Goodix-TS 0-005d: I2C transfer error: -6
[    9.378764] Goodix-TS 0-005d: I2C write end_cmd error
[    9.387600] systemd-journald[294]: Received client request to flush runtime journal.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started udev Kernel Device Manager.
[    9.961494] EXT4-fs (mmcblk0p7): recovery complete
[    9.984264] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Mount partitions.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[   11.536837] st,stm32-spdifrx 4000d000.audio-controller: No cache defaults, reading back from HW
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
[   11.597889] stm32-dfsdm 4400d000.dfsdm: SPI clock not accurate
[   11.602379] stm32-dfsdm 4400d000.dfsdm: 24573875 = 2048000 * 12 + 2045875
[   11.615814] mc: Linux media interface: v0.10
         Starting Load/Save Screen …f backlight:panel-backlight...
[   11.676674] wm8994 0-001b: supply DCVDD not found, using dummy regulator
[   11.749530] wm8994 0-001b: supply AVDD1 not found, using dummy regulator
[   11.773014] videodev: Linux video capture interface: v2.00
[  OK  ] Started Load/Save Screen B… of backlight:panel-backlight.
[  OK  ] Reached target Hardware activated USB gadget.
[   11.978079] stm32-dcmi 4c006000.dcmi: Probe done
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily apt download activities.
[   12.052288] stm32-hash 54002000.hash: will run requests pump with realtime priority
[  OK  ] Started Daily Cleanup of Temporary Directories.
[   12.074291] stm32-cryp 54001000.cryp: will run requests pump with realtime priority
[  OK  ] Reached target Timers.
[   12.109242] ov5640 0-003c: supply AVDD not found, using dummy regulator
[   12.110123] wm8994 0-001b: WM8994 revision D CUST_ID 00
[   12.114915] ov5640 0-003c: supply DVDD not found, using dummy regulator
[   12.127557] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   12.165739] wm8994 0-001b: No interrupt specified, no interrupts
[   12.179790] stm32-cryp 54001000.cryp: Initialized
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[   12.440835] stm32-crc32 58009000.crc: Initialized
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started    12.536763] galcore: loading out-of-tree module taints kernel.
;39mSystem Logging Service.
[  OK  ] Started D-Bus System Message Bus.
[   12.734680] Galcore version 6.4.3.279124
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Netdata, Real-time performance monitoring...
         Starting Login Service...
[  OK  ] Started TEE Supplicant.
         Starting Enable USB Ethernet gadget...
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[   13.679168] using random self ethernet address
[   13.682242] using random host ethernet address
[   13.877854] usb0: HOST MAC 60:eb:4a:5c:64:0b
[   13.880853] usb0: MAC 62:d1:99:ce:d3:71
[   13.914421] dwc2 49000000.usb-otg: bound driver configfs-gadget
[  OK  ] Started Netdata, Real-time performance monitoring.
[  OK  ] Started Enable USB Ethernet gadget.
[   15.034653] wm8994-codec wm8994-codec: Failed to request Mic1 detect IRQ: -22
[   15.040444] wm8994-codec wm8994-codec: Failed to request Mic1 short IRQ: -22
[   15.072882] wm8994-codec wm8994-codec: Failed to request Mic2 detect IRQ: -22
[   15.078691] wm8994-codec wm8994-codec: Failed to request Mic2 short IRQ: -22
[  OK  ] Started Login Service.
[  OK  ] Created slice system-weston.slice.
[  OK  ] Reached target Network (Pre).
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Save/Restore Sound Card State...
         Starting Network Service...
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Reached target Sound Card.
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
[   17.040598] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[   17.076293] dwmac4: Master AXI performs any burst length
[   17.080192] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[   17.102780] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.116185] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[   17.142849] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started IIO Daemon.
[  OK  ] Started Respond to IPv6 Node Information Queries.
         Starting Sound Service...
[  OK  ] Started Network Router Discovery Daemon.
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Target Communication Framework agent.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Reached target Login Prompts.
         Starting Weston Wayland Compositor (on tty7)...
[  OK  ] Started Weston Wayland Compositor (on tty7).
[  OK  ] Created slice User Slice of UID 0.
         Starting User Runtime Directory /run/user/0...
[  OK  ] Started User Runtime Directory /run/user/0.
         Starting User Manager for UID 0...
[  OK  ] Started Sound Service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[  OK  ] Started User Manager for UID 0.
[  OK  ] Started Session c1 of user root.
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17 stm32mp1 ttySTM0
Last login: Sun Sep 20 10:44:11 UTC 2020 on tty7
root@stm32mp1:~#
For ecosystem release v3.0.0 More info.png :
3. Basic commands[edit | edit source]
3.1. Printing distribution specific information[edit | edit source]
root@stm32mp1:~# cat /etc/build
Build Configuration:  |
BB_VERSION = 1.46.0
BUILD_SYS = x86_64-linux
NATIVELSBSTRING = universal
MACHINE = stm32mp1
DISTRO = openstlinux-weston
DISTRO_VERSION = 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17
TARGET_FPU = hard
MANIFESTVERSION = ostl-21-11-17-rc4
DISTRO_CODENAME = dunfell
ACCEPT_EULA_stm32mp1 = 1
GCCVERSION = 9.%
Layer Revisions:      |
meta-python       = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-oe           = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-gnome        = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-initramfs    = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-multimedia   = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-networking   = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-webserver    = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-filesystems  = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-perl         = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-st-stm32mp   = default.xml:3d49b4b37ab3d5b80047e494b3fd459da00ff4ba
meta-qt5          = default.xml:b4d24d70aca75791902df5cd59a4f4a54aa4a125
meta-st-openstlinux = default.xml:9268cd36c765295f1abb8180f08d5502af2d1fd9
meta              = default.xml:c7d2281eb6cda9c1637c20b3540b142073bca235
3.2. Printing system information[edit | edit source]
root@stm32mp1:~# uname -a
Linux stm32mp1 5.10.61 #1 SMP PREEMPT Thu Aug 26 12:51:21 UTC 2021 armv7l armv7l armv7l GNU/Linux
3.3. Printing Linux kernel and GCC versions[edit | edit source]
root@stm32mp1:~# cat /proc/version
3.4. Printing the amount of disk space available on all mounted file systems[edit | edit source]
root@stm32mp1:~# df -h
devtmpfs        367M     0  367M   0% /dev
/dev/mmcblk0p6  683M  470M  164M  75% /
tmpfs           433M   64K  433M   1% /dev/shm
tmpfs           433M  8.9M  425M   3% /run
tmpfs           433M     0  433M   0% /sys/fs/cgroup
tmpfs           433M   20K  433M   1% /tmp
/dev/mmcblk0p4   56M   15M   38M  28% /boot
/dev/mmcblk0p5   14M  6.8M  6.2M  53% /vendor
tmpfs           433M  144K  433M   1% /var/volatile
/dev/mmcblk0p7   27G   38M   25G   1% /usr/local
tmpfs            87M     0   87M   0% /run/user/0
3.5. ssh connection (only if the Ethernet cable is connected)[edit | edit source]
Board $> ip addr show eth0
  • On the host computer, connect the terminal to the board using ssh
PC $> ssh root@xx.xx.xx.xx
root@stm32mp1:~#
