Subpart - STM32MP2 - Starter Package
This article gathers the information that applies to any STM32MP2 series' boards More info green.png.
To start efficiently the board, it's recommended to go through the Starter Package article relative to your board: Category:Starter Package
That's the reason why the steps 2, 3 and 6 referenced in this article depend on the considered board:
  • Step 2 refers to:
  • Step 3 refers to:
  • Step 6 refers to:
2. Checking the boot sequence[edit | edit source]
The information displayed below might differ from that on your own application, and should just be considered as an example.
First information scrolled on the remote Terminal during boot
Last information scrolled on the remote Terminal during boot
In parallel, a U-Boot splash screen picture is displayed on the board display (if one is connected to the board).DSI U-Boot splash screen.png
A user space graphical boot splash screen (PSplash) picture is then briefly displayed on the board display (if one is connected to the board).DSI user splash screen.png
When the boot process is complete, the launcher application is shown on the board display (if one is connected to the board).
3. Mouse, keyboard and Ethernet hot-plugs[edit | edit source]
[  926.786326] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[  926.961413] input: Logitech Optical USB Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C016.0001/input/input2
[  926.975098] hid-generic 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-5800d000.usbh-ehci-1.1/input0
[ 1215.356377] stm32-dwmac 5800a000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1215.363377] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready
4. Remote and local Terminal programs[edit | edit source]
The remote Terminal on your host PC can be used to enter command lines, as shown below with the ip command to query the network interface parameters:
Example of command (ip) executed on the remote Terminal program
Icon to launch a local Terminal program
Wayland Terminal program
Example of command (ip addr) executed on the Wayland Terminal program
5. Executing basic commands[edit | edit source]
The outputs of the commands executed below are examples; the outputs obtained might differ.
5.1. Having a look at the OpenSTLinux directory structure[edit | edit source]
5.2. Identifying the software running on board[edit | edit source]
Obviously, what you obtain might differ from what is displayed on the Output example column.
For ecosystem release v6.1.0 More info.png[edit | edit source]
Software How to get its version Output example
TF-A TF-A Version number
NOTICE: BL2: v2.10-stm32mp1-r2.0(debug):lts-v2.10.13-dirty
U-Boot See the version displayed in the console
2023.10-stm32mp-r2 [...]
Linux kernel
cat /proc/version
Linux version 6.6.78 (xxxx@yyyy) (aarch64-ostl-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) [...]
GCC
cat /proc/version
Linux version 6.6.78 (xxxx@yyyy) (aarch64-ostl-linux-gcc (GCC) 13.3.0) [...]
Yocto Project
grep DISTRO_CODENAME /etc/build
DISTRO_CODENAME = scarthgap
Weston
weston --version
weston 13.0.1
GStreamer
gst-play-1.0 --version
GStreamer 1.22.12
GPU (only on STM32MP25x lines More info.png)
6.4.21.1.1058597 built [...]
5.3. Configuration tips[edit | edit source]
5.4. Getting board IP address[edit | edit source]
ip addr show end0
3: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    inet xx.xx.xx.xx/xx brd xx.xx.xx.xx scope global dynamic end0
    inet6 xxxx::xx:xx:xx:xx/xx scope link
  • Get the IP address of your board with the ifconfig Linux command line (a deprecated but well-known command):
ifconfig end0
end0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:xx.xx.xx.xx  Bcast:xx.xx.xx.xx  Mask:255.255.252.0
          inet6 addr: xxxx::xx:xx:xx:xx/xx Scope:Link
          RX packets:2619 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1311 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:353250 (344.9 KiB)  TX bytes:118305 (115.5 KiB)
          Interrupt:247
5.5. Copying a file from your host PC to your board (and reciprocally)[edit | edit source]
5.6. Miscellaneous commands[edit | edit source]
The outputs of the commands executed below are examples; the outputs that you obtain might differ.
5.6.1. Printing distribution specific information[edit | edit source]
cat /etc/os-release
ID=openstlinux-weston
NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro)"
VERSION="5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 (Scarthgap)"
VERSION_ID=5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11
VERSION_CODENAME="scarthgap"
PRETTY_NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11 (Scarthgap)"
CPE_NAME="cpe:/o:openembedded:openstlinux-weston:5.0.8-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11"
Where:
ID A lower-case string identifying the operating system
NAME A string identifying the operating system
VERSION A string identifying the operating system version, including a release code name
VERSION_ID A lower case string identifying the operating system version
VERSION_CODENAME Code name for the distribution
PRETTY_NAME A full pretty name of the release
CPE_NAME A CPE name for the operating system, following the Common Platform Enumeration Specification[1]
5.6.2. Printing system information[edit | edit source]
uname -a
Linux stm32mp2-XX-XX-XX 6.6.78 #1 SMP PREEMPT Mon Feb 17 08:40:43 UTC 2025 aarch64 GNU/Linux
Where:
Linux Kernel name
stm32mp2-XX-XX-XX Network node hostname
6.6.78 Kernel release
#1 SMP PREEMPT Mon Feb 17 08:40:43 UTC 2025 Kernel version
aarch64 Machine hardware name
GNU/Linux Operating system
5.6.3. Printing Linux kernel and GCC versions[edit | edit source]
cat /proc/version
Linux version 6.6.78 (oe-user@oe-host) (aarch64-ostl-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Mon Feb 17 08:40:43 UTC 2025
Where:
Linux Kernel name
version 6.6.78 Kernel release
(xxxx@yyyy) Person (xxxx) who compiled the kernel, and machine (yyyy) where it happened
(aarch64-ostl-linux-gcc (GCC) 13.3.0 ) Version of the GCC compiler used to compile the kernel
#1 SMP PREEMPT Mon Feb 17 08:40:43 UTC 2025 Kernel version; type of kernel (SMP) and date and time of the kernel compilation
5.6.4. Printing the amount of disk space available on all mounted file systems[edit | edit source]
df -h
devtmpfs         116M     0  116M   0% /dev
/dev/mmcblk0p10  684M  453M  184M  72% /
tmpfs            195M  176K  195M   1% /dev/shm
tmpfs             78M  8.8M   70M  12% /run
tmpfs            4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs            195M   16K  195M   1% /tmp
/dev/mmcblk0p8    55M   39M   12M  77% /boot
/dev/mmcblk0p9    14M  5.9M  6.8M  47% /vendor
tmpfs            195M   96K  195M   1% /var/volatile
/dev/mmcblk0p11   14G   45M   13G   1% /usr/local
tmpfs             39M  4.0K   39M   1% /run/user/1000
tmpfs             39M     0   39M   0% /run/user/0
Where:
Filesystem Source of the mount point, usually a device
Size Total size in human readable format (e.g. 1K, 234M, 2G)
Used Used size in human readable format
Available Available size in human readable format
Use% Percentage of used size divided by the total size
Mounted on Mount point
