STM32MPU Distribution Package - OpenSTLinux distribution
This article aims to give the following information:
  • How to download and install the latest OpenSTLinux distribution for the STM32 microprocessors series.
  • Where to find the associated release note.
  • Where to find the previous releases (archives).
For more specific information, go through the Distribution Package article relative to your STM32 microprocessors series: Category:Distribution Package
1. STM32MPU-Ecosystem-v6.1.0 release[edit | edit source]
  • The STM32MPU OpenSTLinux distribution is delivered through a manifest repository location and a manifest revision.
  • Install the STM32MPU OpenSTLinux distribution: openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11
Warning DB.png Important
Yocto is using absolute directory path to give names to intermediate files. If the path is too long, Yocto build fails because file names exceed the maximum size supported by the file system. In that case, installation directory path should be renamed to reduce the overall absolute path name.
STM32MPU Distribution Package OpenSTLinux distribution - STM32MPU-Ecosystem-6.1.0 release
Installation
Check first here, if a minor release based on this ecosystem release v6.1.0 More info.png is already published.
If a minor release exists, replace the tag used below, and in other wiki articles, by the tag provided with the minor release.
repo init -u https://github.com/STMicroelectronics/oe-manifest.git -b refs/tags/openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11
Note: "ERROR 404" may appear during "repo init" command without any impact on the process.
  • Synchronize the local project directories with the remote repositories specified in the manifest (more details on 'repo sync' here).
repo sync
Release note
  • When installed, the OpenSTLinux Distribution Package is available with following tree structure:
Distribution-Package                      OpenSTLinux distribution
├── layers
│    ├── meta-st
│    │   │   ├── recipes-bsp
│    │   │   │   ├── ddr-firmware         Firmware for DDR PHY on STM32MP
│    │   │   │   ├── fip-stm32mp          FIP generation
│    │   │   │   ├── trusted-firmware-m   For STM32MP2 series - Recipes for TF-M
│    │   │   ├── recipes-connectivity
│    │   │   │   └── bluetooth            Systemd service to suspend/resume correctly bluetooth
│    │   │   ├── recipes-core
│    │   │   │   ├── [...]                bbappend recipes to update some core services
│    │   │   │   ├── external-dt          Recipes for providing device tree files for STM32 MPU devices outside of BSP components
│    │   │   │   ├── m4coredump           For STM32MP15x lines More info.png only - Recipes for script to manage coredump of cortexM4
│    │   │   │   ├── m4projects           For STM32MP15x lines More info.png only - Recipes for firmware examples for Cortex M4
│    │   │   │   ├── stm32mp2projects     For STM32MP2 series  - Recipes for firmware examples for Cortex M33/M0
│    │   │   │   └── stm32mp-g0           For STM32MP13x lines More info.png only - Recipes for G0 USB firmware
│    │   │   │   ├── linux-firmware       Recipes for Linux firmwares (example, Bluetooth firmware)
│    │   │   │   └── optee                Recipes for OPTEE
│    │   │   ├── recipes-st
│    │   │   │   ├── images               Recipes for the bootfs and userfs partitions binaries
│    │   └── scripts
2. Archives Archive box.png[edit | edit source]
This wiki is for the v6 ecosystem releases. For information about the previous ecosystem releases, go through the Wiki archives.
