STM32MP1 internal peripherals assignment table template
1. Boot time assignment table for STM32MP1 series[edit | edit source]
(ROM code)
(TF-A BL2)
nonsecure
(U-Boot)
2. Runtime assignment table for STM32MP13x lines More info.png[edit | edit source]
nonsecure
3. Runtime assignment table for STM32MP15x lines More info.png[edit | edit source]
nonsecure
Cortex-M4
