Subpart - STM32MP1 - Starter Package
This article gathers the information that applies to any STM32MP15 board.
To start efficiently the board, it's recommended to go through the Starter Package article relative to your board: Category:Starter Package
That's the reason why the steps 2, 3 and 6 referenced in this article depend on the considered board:
2. Checking the boot sequence[edit source]
Assuming you have performed the optional step 6 above, the information (coming successively from the U-Boot and the Linux operating system that is booting on the board), should be displayed on the host PC Terminal.
The information displayed below might differ from that on your own application, and should just be considered an example.
First information scrolled on the remote Terminal during boot
Last information scrolled on the remote Terminal during boot
In parallel, a U-Boot splash screen picture is displayed on the DSI display (if one is connected to the board).DSI U-Boot splash screen.png
A user space graphical boot splash screen (PSplash) picture is then briefly displayed on the HDMI monitor if one is connected to the board, or otherwise on the DSI display (if one is connected to the board).DSI user splash screen.png
launcher application layer shown on the HDMI monitor or on the DSI display
3. Mouse, keyboard and Ethernet hot-plugs[edit source]
[  926.786326] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[  926.961413] input: Logitech Optical USB Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C016.0001/input/input2
[  926.975098] hid-generic 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-5800d000.usbh-ehci-1.1/input0
[ 1215.356377] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1215.363377] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
4. Remote and local Terminal programs[edit source]
Example of command (ifconfig) executed on the remote Terminal program
Icon to launch a local Terminal program
Wayland Terminal program
Example of command (ip addr) executed on the Wayland Terminal program
5. Executing basic commands[edit source]
The outputs of the commands executed below are examples; the outputs obtained might differ.
5.1. Having a look at the OpenSTLinux directory structure[edit source]
5.2. Identifying the software running on board[edit source]
Obviously, what you obtain might differ from what is displayed on the Output example column.
5.2.1. For ecosystem release v2.1.0[edit source]
Software How to get its version Output example
TF-A TF-A Version number
NOTICE: BL2: v2.2-r2.0(debug):v2.2-dirty
U-Boot See the version displayed in the console
2020.01-stm32mp-r2 [...]
Linux kernel
 cat /proc/version
Linux version 5.4.56 (xxxx@yyyy) (gcc version 9.3.0 (GCC)) [...]
GCC
 cat /proc/version
Yocto Project
 grep DISTRO_CODENAME /etc/build
DISTRO_CODENAME = dunfell
Weston
 weston --version
weston 8.0.0
GStreamer
 gst-play-1.0 --version
GStreamer 1.16.2
GPU
6.4.3.279124 built [...]
5.2.2. For ecosystem release v2.0.0[edit source]
NOTICE: BL2: v2.2-r1.0(debug):v2.0-r3.0
2020.01-stm32mp-r1 [...]
Linux kernel
 cat /proc/version
Linux version 5.4.31 (xxxx@yyyy) (gcc version 9.3.0 (GCC)) [...]
GCC
 cat /proc/version
Yocto Project
Weston
 weston --version
weston 8.0.0
GStreamer
GStreamer 1.16.2
GPU
6.4.1.244507 built [...]
5.3. Configuration tips[edit source]
5.4. Getting board IP address[edit source]
 ip addr show eth0
    inet6 xxxx::xx:xx:xx:xx/xx scope link
  • Get the IP address of your board with the ifconfig Linux command line (a deprecated but well-known command):
 ifconfig eth0
eth0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:xx.xx.xx.xx  Bcast:xx.xx.xx.xx  Mask:255.255.252.0
          inet6 addr: xxxx::xx:xx:xx:xx/xx Scope:Link
          RX packets:2619 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1311 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:353250 (344.9 KiB)  TX bytes:118305 (115.5 KiB)
          Interrupt:247
5.5. Copying a file from your host PC to your board (and reciprocally)[edit source]
5.6. Miscellaneous commands[edit source]
The outputs of the commands executed below are examples; the outputs that you obtain might differ.
5.6.1. Printing distribution specific information[edit source]
 cat /etc/os-release
ID="openstlinux-weston" NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro)" VERSION="3.1-openstlinux-20-06-10-internal (dunfell)" VERSION_ID="3.1-openstlinux-20-06-10-internal" PRETTY_NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-20-06-10-internal (dunfell)"
Where:
ID A lower-case string identifying the operating system
NAME A string identifying the operating system
VERSION A string identifying the operating system version, including a release code name
VERSION_ID A lower case string identifying the operating system version
PRETTY_NAME A full pretty name of the release
5.6.2. Printing system information[edit source]
 uname -a
Linux stm32mp1 5.4.56 #1 SMP PREEMPT Wed Aug 5 07:59:52 UTC 2020 armv7l armv7l armv7l GNU/Linux
Where:
Linux Kernel name
stm32mp1 Network node hostname
5.4.56 Kernel release
#1 SMP PREEMPT Wed Aug 5 07:59:52 UTC 2020 Kernel version
armv7l Machine hardware name
GNU/Linux Operating system
5.6.3. Printing Linux kernel and GCC versions[edit source]
 cat /proc/version
Linux version 5.4.31 (xxxx@yyyy) (gcc version 9.3.0 (GCC)) #1 SMP PREEMPT Wed Apr 8 07:08:47 UTC 2020
Where:
Linux Kernel name
version 5.4.31 Kernel release
(xxxx@yyyy) Person (xxxx) who compiled the kernel, and machine (yyyy) where it happened
(gcc version 9.3.0 (GCC) ) Version of the GCC compiler used to compile the kernel
#1 SMP PREEMPT Wed Apr 8 07:08:47 UTC 2020 Kernel version; type of kernel (SMP) and date and time of the kernel compilation
5.6.4. Printing the amount of disk space available on all mounted file systems[edit source]
 df -h
/dev/root       719M  342M  339M  51% /
devtmpfs        372M     0  372M   0% /dev
tmpfs           436M     0  436M   0% /dev/shm
tmpfs           436M   14M  423M   4% /run
tmpfs           436M     0  436M   0% /sys/fs/cgroup
tmpfs           436M  4.0K  436M   1% /tmp
/dev/mmcblk0p4   58M  8.2M   46M  16% /boot
/dev/mmcblk0p7  6.4G   68M  6.1G   2% /usr/local
tmpfs           436M  128K  436M   1% /var/volatile
/dev/mmcblk0p5   15M  8.2M  5.3M  61% /vendor
tmpfs            88M     0   88M   0% /run/user/0
Where:
Filesystem Source of the mount point, usually a device
Size Total size in human readable format (e.g. 1K, 234M, 2G)
Used Used size in human readable format
Available Available size in human readable format
Use% Percentage of used size divided by the total size
Mounted on Mount point
