Ethernet device tree configuration
This article explains how to configure the Ethernet when it is assigned to the Linux® OS. In that case, it is controlled by the Ethernet framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the Ethernet peripheral, used by the STM32 DWMAC driver.
The Ethernet is a multifunction device.
Each function is represented by a separate binding document:
  • "Generic" Ethernet device tree bindings [1]
  • specific STM32 ETH device tree bindings[2]
Ethernet peripheral nodes are located in stm32mp151.dtsi [3] file with a disabled status and some required properties such as:
  • Physical base address and size of the device register map
  • STM32 DWMAC interrupts
  • stmmaceth clock and Rx, Tx clocks
This is a set of properties that may not vary for a given STM32MP device, such as: register addresses, interrupts, clocks, ...
ethernet0: ethernet@5800a000 {
	compatible = "st,stm32mp1-dwmac", "snps,dwmac-4.20a";
	reg = <0x5800a000 0x2000>;
	reg-names = "stmmaceth";
        interrupts-extended = <&intc GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>,
                              <&exti 70 IRQ_TYPE_LEVEL_HIGH>;
        interrupt-names = "macirq",
                          "eth_wake_irq";
	clock-names = "stmmaceth",
		      "mac-clk-tx",
		      "mac-clk-rx",
		      "eth-ck",
		      "ethstp";
	clocks = <&rcc ETHMAC>,
		 <&rcc ETHTX>,
		 <&rcc ETHRX>,
		 <&rcc ETHCK_K>,
		 <&rcc ETHSTP>;
	st,syscon = <&syscfg 0x4>;
	snps,mixed-burst;
	snps,pbl = <2>;
        snps,en-tx-lpi-clockgating;
	snps,axi-config = <&stmmac_axi_config_0>;
	snps,tso;
	power-domains = <&pd_core>;
	status = "disabled";
The required and optional properties are fully described in the bindings files.
3.2. Ethernet DT configuration (board level)[edit source]
These DT are same between U-Boot and kernel OS
The device tree board file (.dts) contains all hardware configurations related to board design. The DT node ("ethernet") should be updated to:
  • Enable the Ethernet block by setting status = "okay".
  • Configure the pins in use via pinctrl, through pinctrl-0 (default pins), pinctrl-1 (sleep pins) and pinctrl-names.
  • Configure Ethernet interface used phy-mode = "rgmii"., (rmii, mii, gmii).
  • Configure Ethernet max speed max-speed = <1000>"..
&ethernet0 {
	status = "okay";
	pinctrl-0 = <&ethernet0_rgmii_pins_a>;
	pinctrl-1 = <&ethernet0_rgmii_pins_sleep_a>;
	phy-mode = "rgmii";
	max-speed = <1000>;
	phy-handle = <&phy0>;
	mdio0 {
		#address-cells = <1>;
		#size-cells = <0>;
		compatible = "snps,dwmac-mdio";
		phy0: ethernet-phy@1 {
			reg = <1>;
3.3. DT configuration examples at board level[edit source]
The example below shows how to configure and enable an Ethernet instance
&ethernet0 {
   status = "okay";                             /* enable ethernet0 */
   pinctrl-0 = <&ethernet0_rmii_pins_a>;        /* configure pinctrl modes for ethernet0 */
   pinctrl-1 = <&ethernet0_rmii_pins_sleep_a>;  /* configure ethernet0_rmii_pins_sleep_a as sleep pinctrl configuration for ethernet0 */
   phy-mode = "rmii";                           /* configure ethernet phy mode for ethernet0 */
   max-speed = <100>;                           /* configure ethernet max speed for ethernet0 */
   mdio0 {
       #size-cells = <0>;
           reg = <1>;                           /* configure ethernet phy @ for ethernet0 */
How to configure Ethernet for :
3.3.1. RMII with Crystal on PHY (Reference clock (standard RMII clock name) is provided by a Phy Crystal)[edit source]
   &ethernet0 {
       status = "okay";
       phy-mode = "rmii";
       max-speed = <100>;
       mdio0 {
               #size-cells = <0>;
               phy0: ethernet-phy@0 {
                       reg = <0>;
3.3.2. RMII with 25MHz on ETH_CLK (no PHY Crystal), REF_CLK from PHY (Reference clock (standard RMII clock name) is provided by a PHY)[edit source]
   &ethernet0 {
       status = "okay";
       phy-mode = "rmii";
       max-speed = <100>;
       mdio0 {
               #size-cells = <0>;
                       reg = <0>;
+ update stm32mp15-pinctrl.dtsi [4] to add ETHCK pin in ethernet0_rmii_pins_* node:
For example:
 <STM32_PINMUX('G', 8, AF2)>, /* ETH_RMII_ETHCK */
+ Need also to update TFA devicetree to generate 25Mhz clock (from PLL4P or PLL3Q):
for example if PLL4P in ed1 board: update fdts/stm32mp15xx-edx.dtsi
st,pkcs = <
 CLK_CKPER_HSE
 CLK_FMC_ACLK
 CLK_QSPI_ACLK
 - CLK_ETH_DISABLED
 + CLK_ETH_PLL4P
 /* VCO = 600.0 MHz => P = 25, Q = 50, R = 50 */
   pll4: st,pll@3 {
     compatible = "st,stm32mp1-pll";
     reg = <3>;
     cfg = < 1 49 23 11 11 PQR(1,1,1) >;
3.3.3. RMII with 50MHz on ETH_CLK (no PHY Crystal), internal REF_CLK from RCC (Reference clock (standard RMII clock name) is provided by a RCC SoC internal clock)[edit source]
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,eth_ref_clk_sel;               /* In case of U-Boot */
       st,eth-ref-clk-sel;               /* In case of Linux Kernel */
       snps,tso;
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,eth-ref-clk-sel;               /* In case of U-Boot */
       st,ext-phyclk;               /* In case of Linux Kernel */
       snps,tso;
For ecosystem release > v3.1.0
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,ext-phyclk;
       snps,tso;
   &ethernet0 {
       status = "okay";
       phy-mode = "rmii";
       max-speed = <100>;
       mdio0 {
               #size-cells = <0>;
                       reg = <0>;
+ update stm32mp15-pinctrl.dtsi to add ETHCK pin in ethernet0_rmii_pins_* node:
For example:
+ Need also to update TFA to generate 50Mhz clock (from PLL4P or PLL3Q):
st,pkcs = <
 CLK_CKPER_HSE
 CLK_FMC_ACLK
 CLK_QSPI_ACLK
 - CLK_ETH_DISABLED
 + CLK_ETH_PLL4P
 /* VCO = 508.0 MHz => P = 50, Q = 60, R = 60 */
   pll4: st,pll@3 {
     reg = <3>;
    cfg = < 1 49 11 9 9 PQR(1,1,1) >;
3.3.4. RGMII with Crystal on PHY, CLK125 from PHY (Reference clock (standard RGMII clock name) is provided by a Phy Crystal)[edit source]
   &ethernet0 {
       status = "okay";
       phy-mode = "rgmii";
       max-speed = <1000>;
       mdio0 {
               #size-cells = <0>;
                       reg = <0>;
3.3.5. RGMII with 25MHz on ETH_CLK (no PHY Crystal), CLK125 from PHY (Reference clock (standard RGMII clock name) is provided by a RCC SoC internal clock)[edit source]
   &ethernet0 {
       status = "okay";
       phy-mode = "rgmii";
       max-speed = <1000>;
       mdio0 {
               #size-cells = <0>;
                       reg = <0>;
+ update stm32mp15-pinctrl.dtsi to add ETHCK pin in ethernet0_rgmii_pins_* node:
For example:
 <STM32_PINMUX('G', 8, AF2)>, /* ETH_RGMII_ETHCK */
+ Need also to update TFA to generate 25Mhz clock (from PLL4P or PLL3Q):
st,pkcs = <
 CLK_CKPER_HSE
 CLK_FMC_ACLK
 CLK_QSPI_ACLK
 - CLK_ETH_DISABLED
 + CLK_ETH_PLL4P
   pll4: st,pll@3 {
     reg = <3>;
3.3.6. RGMII with Crystal on PHY, no 125Mhz from PHY[edit source]
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,eth_clk_sel;               /* In case of U-Boot */
       st,eth-clk-sel;               /* In case of Linux Kernel */
       snps,tso;
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,eth-clk-sel;               /* In case of U-Boot */
       snps,tso;
                             <&exti 70 1>;
                         "stm32_pwr_wakeup";
                      "mac-clk-tx",
                      "mac-clk-rx",
                      "eth-ck",
                      "ethstp";
                      <&rcc ETHTX>,
                      <&rcc ETHRX>,
                      <&rcc ETHCK_K>,
                      <&rcc ETHSTP>;
       snps,mixed-burst;
       snps,pbl = <2>;
       st,ext-phyclk;
       snps,tso;
   &ethernet0 {
       status = "okay";
       phy-mode = "rgmii";
       max-speed = <1000>;
       mdio0 {
               #size-cells = <0>;
                       reg = <0>;
+ update stm32mp15-pinctrl.dtsi to delete CLK125 pin (also no need of ETHCK pin) in ethernet0_rgmii_pins_* node:
+ Need also to update TFA to generate 125Mhz clock (from PLL4P or PLL3Q):
st,pkcs = <
 CLK_CKPER_HSE
 CLK_FMC_ACLK
 CLK_QSPI_ACLK
 - CLK_ETH_DISABLED
 + CLK_ETH_PLL4P
 /* VCO = 750.0 MHz => P = 125, Q = 62.5, R = 62.5 */
 pll4: st,pll@3 {
     reg = <3>;
     cfg = < 3 124 5 11 11 PQR(1,1,1) >;
4. How to configure a PHY reset signal[edit source]
Some Ethernet PHY have possibility to drive PHY reset using GPIO
   &ethernet0 {
       status = "okay";
       phy-mode = "rgmii";
       max-speed = <1000>;
       mdio0 {
               #size-cells = <0>;
                       compatible = "ethernet-phy-id0007.c131";
                       reset-gpios = <&gpioa 4 GPIO_ACTIVE_LOW | GPIO_PULL_UP>
                         reset-assert-us = <1000>;
                         reset-deassert-us = <2000>;
                         reg = <0>;
For kernel update see "reset-gpios" in Documentation/devicetree/bindings/net/ethernet-phy.yaml[5]
You need to find and replace value 0007.c131 corresponding to your Ethernet PHY: this can be found in datasheet of the Ethernet PHY, and find PHY Identifier 1 and PHY Identifier 2 registers.
For U-Boot same syntax of kernel, except that "reset-assert-us" and "reset-deassert-us" properties which are not managed (values of this properties are hardcoded in driver (udelay(2)), so you can change these value in function eqos_start_resets_stm32 of file dwc_eth_qos.c[6]
5. How to configure Ethernet using CubeMX[edit source]
