IPCC device tree configuration
This article explains how to configure the IPCC internal peripheral controlled by the Linux Mailbox framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the IPCC peripheral, used by the STM32 IPCC Linux driver.
The IPCC internal peripheral is represented by:
  • The Generic mailbox device tree bindings[1]
  • The STM32 IPCC device tree bindings[2]
The IPCC peripheral node is located in stm32mp151.dtsi [3] file.
ipcc: mailbox@4c001000 {
	compatible = "st,stm32mp1-ipcc";
	#mbox-cells = <1>;
	reg = <0x4c001000 0x400>;
	st,proc-id = <0>;
	interrupts-extended =
		<&exti 61 1>,
		<&intc GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
	interrupt-names = "rx", "tx";
	clocks = <&rcc IPCC>;
	wakeup-source;
	power-domains = <&pd_core>;
	status = "disabled";
This part is used to enable the IPCC hardware on a board:
&ipcc {
	status = "okay";
Below is an example of the remoteproc client using 3 mailbox channels:
&m4_rproc {
	mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>;
	mbox-names = "vq0", "vq1", "shutdown";
