NVIC internal peripheral
  • briefly introduce the NVIC and its main features
  • explain how the NVIC can be configured.
The NVIC is the Arm® Cortex®-M4 interrupt controller. As a result, it cannot be accessed by the Arm Cortex-A7 core.
2.1. Features[edit source]
The NVIC is a non-secure peripheral.
3.1. Boot time[edit source]
The NVIC can be configured through the STM32Cube.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The NVIC can be allocated only to the Arm Cortex-M4 core to be controlled in the STM32Cube by the NVIC HAL driver.
OP-TEE Linux STM32Cube
Core/Interrupts NVIC STM32Cube NVIC driver
Internal peripherals
non-secure
Cortex-M4
Core/Interrupts NVIC NVIC
