DMA internal peripheral
  • briefly introduce the DMA peripheral and its main features
  • explain, when necessary, how to configure the DMA peripheral.
The DMA peripheral is used to perform direct accesses from/to a device or a memory. Each DMA instance supports 8 channels. The selection of the device connected to each DMA channel and controlling the DMA transfers is done via the DMAMUX.
Note: Directly accessing DDR from the DMA is not recommended for high-bandwith or latency-critical transfers. This means that DMA transfers configured by the Arm® Cortex®-A7 operating system, that usually target buffers in external memory, require a hardware mechanism to chain the DMA and a MDMA channel in order to achieve the following flow:
DDR<-> MDMA <-> MCU SRAM <-> DMA <-> device
This feature was already present on STM32H7 microcontroller Series. It is documented in application note AN5001[1].
2.1. Features[edit source]
The DMA is a non-secure peripheral.
3.1. Boot time[edit source]
The DMA is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
Each DMA instance can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the dmaengine framework
  • the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by the DMA HAL driver
OP-TEE Linux STM32Cube
Core/DMA DMA Linux dmaengine framework STM32Cube DMA driver
Internal peripherals
non-secure
Cortex-M4
Core/DMA DMA DMA1 Assignment (single choice)
DMA2 Assignment (single choice)
4. References[edit source]
