DBGMCU internal peripheral
  • briefly introduce the DBGMCU peripheral and its main features
  • explain, when necessary, how to configure the DBGMCU peripheral.
The DBGMCU peripheral is used to configure internal peripherals behavior when one of the cores (Cortex®-A7 or Cortex®-M4) enters in debug mode.
For instance, it allows to freeze a watchdog (IWDG) to avoid getting a watchdog reset when the Cortex®-A7 enters in debug mode (via a breakpoint or JTAG break).
2.1. Features[edit source]
The DBGMCU is a non secure peripheral.
3.1. Boot time[edit source]
DBGMCU is partly initialized by the FSBL at boot time in order to freeze IWDG2 when the Cortex®-A7 enters in debug mode.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
There is no real runtime support for DBGMCU. Instead, users who need to freeze some peripherals for a debug session should complete the minimal initialization done in the FSBL with their needs.
OP-TEE Linux STM32Cube
Trace & Debug DBGMCU
Internal peripherals
non-secure
Cortex-M4
Trace & Debug DBGMCU DBGMCU No assignment
