How to debug OP-TEE
1. Purpose[edit source]
  • There are two main ways to debug OP-TEE core: using embedded traces, or using JTAG/SWD to access the secure world.
  • The OP-TEE trusted applications and libraries provide debug support relying on embedded traces only.
2. Debugging OP-TEE core[edit source]
2.1. OP-TEE Version number[edit source]
I/TC: OP-TEE version:<tag> #<buildcount> <date> <arch>
that is:
I/TC: OP-TEE version: openstlinux-19-01-11-10-g56ef3b0 #1 Wed Jan 30 09:12:56 UTC 2019 arm
2.2. Embedded assertions[edit source]
   assert(argument > 0);
   return argument - 1;
2.3. Debug with traces[edit source]
Value Name Description with related macros
0 - All trace messages are disabled
1 Error trace level Only non-tagged and error trace messages are embedded: MSG(), MSG_RAW(), EMSG(), EMSG_RAW()
2 Info trace level + info trace messages: IMSG(), IMSG_RAW()
3 Debug trace level + debug trace messages: DMSG(), DMSG_RAW()
4 Flow trace level + flow trace messages: FMSG(), FMSG_RAW()
chosen {
More information about OP-TEE build and update is available in the STM32MP15 OP-TEE article.
2.4. Stack unwind support[edit source]
2.5. Debug with GDB[edit source]
2.5.1. Debug boot sequence[edit source]
Linker script and memory map
                0x000000002ffc0000                . = 0x2ffc0000
                0x0000000000000001                ASSERT (0x1, text start should align to 32bytes)
                0x000000002ffc0000                __text_start = .
                0x000000002ffc0000                __flatmap_unpg_rx_start = ((__text_start / 0x1000) * 0x1000)
.text           0x000000002ffc0000     0xc538
 *(SORT_BY_ALIGNMENT(.text._start))
 .text._start   0x000000002ffc0000       0x98 out/stm32mp157c-ev1/core/arch/arm/kernel/generic_entry_a32.o
                0x000000002ffc0000                _start  -> OP-TEE Load address
(gdb) hb _start
2.5.2. Debugging during runtime execution[edit source]
(gdb) hb stm32_sip_service
(gdb) continue
3. Debugging OP-TEE trusted applications[edit source]
3.1. Embedded assertions[edit source]
3.2. Debug with traces[edit source]
3.3. Stack unwind support[edit source]
These backtrace messages are generated by the OP-TEE core, which must be built with CFG_UNWIND=y as described in the section above.
4. References[edit source]
