This article explains how to configure the RNG internal peripheral when it is assigned to the Linux® OS. In that case, it is controlled by the Hardware random framework.
The configuration is performed using the device tree mechanism that provides a hardware description of the RNG peripheral, used by the STM32 RNG Linux driver.
The RNG is represented by the STM32 RNG device tree bindings[1]
The RNG node is declared in stm32mp151.dtsi[2]. It describes the hardware register address, clock and reset.
rng1: rng@54003000 { Comments compatible = "st,stm32-rng"; reg = <0x54003000 0x400>; --> Register location and length clocks = <&scmi0_clk CK_SCMI0_RNG1>; resets = <&scmi0_reset RST_SCMI0_RNG1>; status = "disabled"; };
This part is used to enable the RNG used on a board which is done by setting the status property to okay.
A clock-error-detect property is available depending the clock choosen for entropy. It can be enabled to manage the clock detection.
&rng1 { status = "okay"; clock-error-detect; };
