- briefly introduce the RNG peripheral and its main features
- explain how to configure the RNG peripheral.
The RNG peripheral is used to provide 32-bit random numbers.
2.1. Features[edit source]
RNG1 is a secure peripheral (under ETZPC control).
RNG2 is a non-secure peripheral.
3.1. Boot time[edit source]
RNG instances are not used as boot devices.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
RNG instances can be allocated to:
- the Arm® Cortex®-A7 secure core to be controlled in OP-TEE with OP-TEE RNG driver
- the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the Linux hardware random framework
- the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by STM32Cube RNG driver
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
Security | RNG | OP-TEE RNG driver | Linux hardware random framework | STM32Cube RNG driver |
Cortex-M4 (STM32Cube) | |||
Security | RNG | RNG1 | ☐ | ☐ | Assignment (single choice) | |
RNG2 | ☐ |
Not applicable.
