HASH internal peripheral
  • briefly introduce the HASH peripheral and its main features
  • explain, when necessary, how to configure the HASH peripheral.
The HASH peripheral is used to compute a message digest.
Digest algorithms could be:
The HASH peripheral is also able to give the HMAC[3] used for authentication using the same algorithm support.
2.1. Features[edit source]
HASH1 is a secure peripheral (under ETZPC control)
HASH2 is a non secure peripheral .
3.1. Boot time[edit source]
HASH1 instance is used as boot device to support binary authentication.
HASH2 is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
HASH1 instance can be allocated to:
HASH2 instance can be allocated to:
OP-TEE Linux STM32Cube
Security HASH OP-TEE HASH driver Linux Crypto framework STM32Cube HASH driver
Internal peripherals
non-secure
Cortex-M4
Security HASH HASH1 Assignment (single choice)
HASH2
Not applicable.
