DMAMUX internal peripheral
  • briefly introduce the DMAMUX peripheral and its main features
  • explain, when necessary, how to configure the DMAMUX peripheral.
The DMAMUX peripheral is used to perform requestor line (or device controller) selection for each channel from DMA instances: there is a single DMAMUX instance to cover both DMA1 and DMA2.
2.1. Features[edit source]
The DMAMUX is a non secure peripheral.
3.1. Boot time[edit source]
The DMAMUX is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DMAMUX manages DMA1 and DMA2 requestor line selection via different registers so it is possible to concurrently access to DMAMUX from Cortex®-A7 non-secure and Cortex®-M4 contexts, as far as each core is only configuring the requestor lines for the DMA instances (DMA1 and/or DMA2) assigned to itself.
Finally, DMAMUX can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the dmaengine framework
  • the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by the DMA HAL driver
OP-TEE Linux STM32Cube
Core/DMA DMAMUX Linux dmaengine framework STM32Cube DMAMUX driver
Internal peripherals
non-secure
Cortex-M4
Core/DMA DMAMUX DMAMUX Shareable (multiple choices supported)
