- briefly introduce the TZC peripheral and its main features
- explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
- explain, when necessary, how to configure the TZC peripheral.
The TZC peripheral is used to filter read/write accesses to the DDR controller according to TrustZone access rights, and according to Non-Secure master Address ID (NSAID) on up to 9 programmable regions.
2.1. Features[edit source]
The TZC is a secure peripheral.
3.1. Boot time[edit source]
The TZC is configured at boot time to setup DDR accesses.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The TZC is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
Security | TZC | OP-TEE TZC driver |
The configuration is applied by the firmware running in the secure context.
This configuration is done in TF-A or in OP-TEE.
Cortex-M4 (STM32Cube) | |||
Security | TZC | TZC | ✓ |
The TZC is an Arm® peripheral: TZC-400 TrustZone Address Space Controller[1]
