STM32CubeProgrammer release note
Revision as of 08:07, 9 October 2019 by Registered User
STM32CubeProgrammer is the official STMicroelectronics tool to download firmware into STMicroelectronics boards.
1. STM32CubeProgrammer - Version 2.2.0[edit source]
Download
Version 2.2.0
  • To access the SetupSTM32CubeProgrammer link and follow instructions to download the package, you need a myST account
Installation
./SetupSTM32CubeProgrammer-2.2.0.linux
export PATH=<my STM32CubeProgrammer install directory>/bin:$PATH
ln -s <my STM32CubeProgrammer install directory>/bin/STM32_Programmer_CLI /home/bin/STM32_Programmer_CLI
User manual
Detailed release note
