CEC internal peripheral
  • briefly introduce the CEC peripheral and its main features
  • explain, when necessary, how to configure the CEC peripheral.
2. Peripheral overview
The CEC (consumer electronics control) or HDMI-CEC is an STM32 internal peripheral that allows to receive/send messages from/to devices, such as TV or tuner, through a HDMI cable.
2.1. Features
Refer to the STM32 CEC presentation [1] for an overview of the CEC hardware block capabilities.
2.2. Security support
The CEC is a non-secure peripheral.
3.1. Boot time
The CEC is not used at boot time.
3.2. Runtime
3.2.1. Overview
The CEC internal peripheral can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the CEC framework
3.2.2. Software frameworks
OP-TEE Linux STM32Cube
Low-speed interface CEC
CEC framework CEC HAL driver
The configuration is applied by the firmware running in the context to which the peripheral is assigned. The configuration can be done alone via the STM32CubeMX tool for all internal peripherals, and then manually completed (particularly for external peripherals), according to the information given in the corresponding software framework article or for Linux® in the CEC device tree configuration article.
3.2.4. Peripheral assignment
Internal peripherals
non-secure
Cortex-M4
Visual CEC CEC Assignment (single choice)
4. How to go further
Refer to the STM32 CEC application note (AN4066) [2] for a detailed description of the CEC peripheral and applicable use-cases.
5. References
