Netstat
This article provides the basic information needed to start using the Linux tool: netstat [1].
2. Introduction[edit source]
Tool STM32MPU Embedded Software distribution STM32MPU Embedded Softwaredistribution for Android™
The STM32MPU distribution for Android™ is not yet available in the v3 ecosystem releases: refer to the Netstat page for the v2 ecosystem releases (in archived wiki).
netstat Monitoring tools netstat[1] prints network connections, routing tables, interface statistics, masquerade connections, and multicast membership information. Yes Yes Yes Yes Yes Yes
netstat is installed by default and ready to be used with all STM32MPU Embedded Software Packages.
It comes through the busybox:
 which netstat | xargs ls -la
/bin/netstat -> /bin/busybox.nosuid
netstat is installed by default and ready to be used with all STM32MPU Embedded Software Packages for Android™.
It comes with the toybox:
/system/bin/netstat -> toybox
Here are basic commands to start with netstat:
  • Display kernel routing information
 netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         10.99.3.254     0.0.0.0         UG        0 0          0 eth0
10.99.0.0       0.0.0.0         255.255.252.0   U         0 0          0 eth0
10.99.3.254     0.0.0.0         255.255.255.255 UH        0 0          0 eth0
  • List out listening-only connections
 netstat -tnl
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:19999           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN
tcp        0      0 10.99.1.237:53          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:953           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:1534            0.0.0.0:*               LISTEN
tcp        0      0 :::19999                :::*                    LISTEN
tcp        0      0 :::5355                 :::*                    LISTEN
tcp        0      0 :::53                   :::*                    LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
5. To go further[edit source]
Additional documentation is available on Internet about netstat. See References.
Refer to Linux® man page[1] for more details on command options.
  • Useful external links
netstat (wikipedia.org) Standard wikipedia.org
netstat examples User Guide binarytides.com
netstat main commands User Guide geekflare.com
