CRC internal peripheral
  • briefly introduce the CRC peripheral and its main features
  • explain how to configure the CRC peripheral.
The CRC peripheral is used to verify data transmission or storage integrity.
2.1. Features[edit source]
CRC1 and CRC2 are non secure peripherals.
3.1. Boot time[edit source]
CRC instances are not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
CRC instances can be allocated to:
OP-TEE Linux STM32Cube
Security CRC
Linux Crypto framework STM32Cube CRC driver
Internal peripherals
non-secure
Cortex-M4
Security CRC CRC1
CRC2
Not applicable.
