QUADSPI internal peripheral
  • briefly introduce the QUADSPI peripheral and its main features
  • explain, when needed, how to configure the QUADSPI peripheral.
The Quad-SPI interface (QUADSPI peripheral) is used to interface the processor with serial NOR Flash and serial NAND Flash memories.
It supports:
  • Single, dual or quad SPI Flash memories
  • A dual-flash mode, allowing to agregate two Flash memories into a virtual single one
  • Dual data rate and memory-mapped modes.
2.1. Features[edit source]
QUADSPI is non secure peripheral.
3. Using the peripheral - associated software[edit source]
3.1. Boot time[edit source]
QUADSPI instance is boot device that support serial boot for Flash programming with STM32CubeProgrammer.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The QUADSPI instances can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the MTD framework
Chapter #Peripheral assignment describes which peripheral instances can be assigned to which context.
OP-TEE Linux STM32Cube
Mass storage QUADSPI Linux MTD framework STM32Cube QUADSPI driver
For Linux kernel configuration, please refer to QUADSPI device tree configuration.
Internal peripherals
non-secure
Cortex-M4
Mass storage QUADSPI QUADSPI Assignment (single choice)
