How to record audio
2. Audio record overview[edit source]
The application audio streams are routed by default through the PulseAudio sound server. PulseAudio exposes audio profiles, which are mapped on the ALSA sound card audio devices. The PulseAudio server provides a command line interface to list audio profiles and to select one, in order to record from a specific audio interface.
3. Examples[edit source]
3.1. Audio record from headset microphone input[edit source]
  • Record from ALSA device
Launch audio record from 'record_codec' ALSA device:
 arecord -D record_codec -f S16_LE -d 10 /tmp/rec.wav
  • Record via PulseAudio
Change Pulseaudio active profile of the sound card, to 'analog-stereo' profile:
 pacmd set-card-profile 0 output:analog-stereo+input:analog-stereo
Launch audio record:
 arecord -d 10 /tmp/rec.wav
3.2. Audio record from digital microphone input[edit source]
Launch audio record from 'record_dfsdm0' ALSA device:
 arecord -D record_dfsdm0 -r 16000 -f S32_LE -c 1 -d 10 /tmp/rec.wav
3.3. Audio record from S/PDIF input[edit source]
Launch audio record from 'record_spdif' ALSA device:
 arecord -D record_spdif -f S32_LE -c 2 -r 48000 -d 10 /tmp/rec.wav
