1. Purpose[edit source]
The purpose of this article is to explain how to configure the digital-to-analog converter (DAC)[1] when the peripheral is assigned to Linux® OS, and in particular:
- how to configure and enable the DAC peripheral
- how to configure the board, the DAC channels, reference voltage regulator and pins.
It is used by the DAC Linux driver that registers relevant information in IIO framework, such as IIO devices, channels and voltage scale.
STM32 DAC device tree bindings[3] deal with all the required or optional properties.
This hardware description is a combination of STM32 and board device tree files. See Device tree for explanations on device tree file split.
The DAC nodes are declared in stm32mp157c.dtsi[4]:
- DT root node ('dac') describes the DAC hardware block parameters such as registers area and clocks.
- DT child nodes ('dac1' and 'dac2') describe DAC channels independently.
dac: dac@address { compatible = "st,stm32h7-dac-core"; ... Template:Highlight dac1: dac@1 { compatible = "st,stm32-dac"; reg = <1>; Template:Highlight ... Template:Highlight }; dac2: dac@2 { compatible = "st,stm32-dac"; reg = <2>; Template:Highlight ... Template:Highlight }; };
Follow the below sequence to configure and enable the DAC on your board:
- Enable DT root node named 'dac' by setting status = "okay".
- Configure pins in use via pinctrl through pinctrl-0 and pinctrl-names.
- Configure analog reference voltage regulator[5] by setting vref-supply = <&your_regulator>.
- Enable DT child node(s) for 'dac1' and/or 'dac2' channels(s) in use by setting status = "okay".
The example below shows how to configure DAC1 and DAC2 channels:
- PA4 and PA5 pins both configured as analog pins (see Pinctrl device tree configuration for more details)
- VREFBUF[6] used as reference voltage
dac_ch1_pins_a: dac-ch1 { pins { pinmux = <STM32_PINMUX('A', 4, ANALOG)>; Template:Highlight }; }; dac_ch2_pins_a: dac-ch2 { pins { pinmux = <STM32_PINMUX('A', 5, ANALOG)>; Template:Highlight }; };
&dac { pinctrl-names = "default"; pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>; Template:Highlight vref-supply = <&vrefbuf>; Template:Highlight status = "okay"; Template:Highlight dac1: dac@1 { status = "okay"; Template:Highlight }; dac2: dac@2 { status = "okay"; Template:Highlight }; };
- ↑ DAC internal peripheral
- ↑ Device tree
- ↑ Template:CodeSource, STM32 DAC device tree bindings
- ↑ Regulator overview
- ↑ Cite error: Invalid
<ref>
tag; no text was provided for refs namedVREFBUF internal peripheral
