LPTIM device tree configuration
Template:ArticleBasedOnModel Template:ArticleMainWriter Template:ArticleApprovedVersion Template:ReviewsComments
The purpose of this article is to explain how to configure the low-power timer (LPTIM)[1] when the peripheral is assigned to Linux® OS, and in particular:
  • how to configure the LPTIM peripheral to enable PWM, trigger, event counter and quadrature encoder
  • how to configure the board, e.g. LPTIM input/output pins
It is used by the LPTIM Linux driver that registers relevant information in PWM and IIO frameworks.
The LPTIM[1] is a multifunction device (MFD).
Each function is represented by a separate binding document:
  • STM32 LPTIM MFD device tree bindings[3] deals with core resources (e.g. registers, clock)
  • STM32 LPTIM PWM device tree bindings[4] deals with PWM interface resources (e.g. PWM pins)
  • STM32 LPTIM trigger device tree bindings[5] deals with LPTIM triggers resources (e.g. trigger output connected to other STM32 internal peripherals)
  • STM32 LPTIM counter device tree bindings[6] deals with LPTIM counter and quadrature encoder resources (e.g. counter/encoder IN[1..2] pins)
The STM32CubeMX can be used to generate the board device tree. Refer to How to configure the DT using STM32CubeMX for more details. Template:ImageMap
LPTIM nodes are declared in stm32mp157c.dtsi[7].
DT root node (aka lptimer1, ..., lptimer5) and DT child nodes describe the LPTIM features such as:
  • PWM
  • trigger
  • event counter and quadrature encoder.
They also describe hardware parameters such as register addresses and clock.
lptimer1: timer@40009000 {
	compatible = "st,stm32-lptimer";                      Template:Highlight
	pwm {
		compatible = "st,stm32-pwm-lp";               Template:Highlight
	trigger@0 {
		compatible = "st,stm32-lptimer-trigger";      Template:Highlight
		reg = <0>;                                    Template:Highlight
	counter {
		compatible = "st,stm32-lptimer-counter";      Template:Highlight
Template:Warning
Follow the below sequence to configure and enable the LPTIM on your board STM32MP15 microprocessor:
  • Enable DT root node for the LPTIM instance in use (e.g lptimer1, ..., lptimer5), with status = "okay";
  • Enable DT child node(s) for the feature(s) in use (PWM output, trigger, event counter and quadrature encoder), with status = "okay";
  • Configure the pins in use via pinctrl, with pinctrl-0, pinctrl-1 and pinctrl-names.
3.3.1. LPTIM1 configured as PWM and trigger source[edit source]
The example below shows how to configure LPTIM1 to act as:
lppwm1_pins_a: lppwm1-0 {
 	pins {
		pinmux = <STM32_PINMUX('G', 13, AF1)>;    Template:Highlight
		bias-pull-down;
		drive-push-pull;
		slew-rate = <0>;
lppwm1_sleep_pins_a: lppwm1-sleep-0 {
	pins {
		pinmux = <STM32_PINMUX('G', 13, ANALOG)>; Template:Highlight
&lptimer1 {
	status = "Template:Highlight";
	pwm {
		pinctrl-0 = <&lppwm1_pins_a>;             Template:Highlight
		pinctrl-1 = <&lppwm1_sleep_pins_a>;
		status = "Template:Highlight";                          Template:Highlight
	trigger@0 {
3.3.2. LPTIM2 configured as counter and quadrature encoder[edit source]
The example below shows how to configure LPTIM2 to act as counter and/or quadrature encoder, with LPTIM2_IN1 and LPTIM2_IN2 pins configured as inputs on PD12 and PD11, respectively (See pinctrl device tree configuration and GPIO internal peripheral)
# part of pin-controller dt node
lptim2_in_pins_a: lptim2-in-pins-0 {
	pins {
		pinmux = <STM32_PINMUX('D', 12, AF3)>, /* LPTIM2_IN1 */
			 <STM32_PINMUX('D', 11, AF3)>; /* LPTIM2_IN2 */
		bias-disabled;
lptim2_sleep_in_pins_a: lptim2-sleep-in-pins-0 {
	pins {
		pinmux = <STM32_PINMUX('D', 12, ANALOG)>, /* LPTIM2_IN1 */
			 <STM32_PINMUX('D', 11, ANALOG)>; /* LPTIM2_IN2 */
&lptimer2 {
	counter {
		pinctrl-0 = <&lptim2_in_pins_a>;          Template:Highlight
		pinctrl-1 = <&lptim2_sleep_in_pins_a>;
  1. Jump up to: 1.0 1.1 LPTIM internal peripheral
  2. Device tree
  3. Template:CodeSource, STM32 LPTIM MFD device tree bindings
  4. Template:CodeSource, STM32 LPTIM PWM device tree bindings
  5. Template:CodeSource, STM32 LPTIM trigger device tree bindings
  6. Template:CodeSource, STM32 LPTIM counter/encoder device tree bindings
  7. Template:CodeSource
  8. ADC internal peripheral
  9. DAC internal peripheral
  10. DFSDM internal peripheral
