DMAMUX internal peripheral
  • briefly introduce the DMAMUX peripheral and its main features
  • explain, when necessary, how to configure the DMAMUX peripheral.
The DMAMUX peripheral is used to perform requestor line (or device controller) selection for each channel from DMA instances: there is a single DMAMUX instance to cover both DMA1 and DMA2.
2.1. Features[edit source]
The DMAMUX is a non secure peripheral.
3.1. Boot time[edit source]
The DMAMUX is not used at boot time.
3.2. Runtime[edit source]
3.2.1. Overview[edit source]
The DMAMUX manages DMA1 and DMA2 requestor line selection via different registers so it is possible to concurrently access to DMAMUX from Cortex®-A7 non-secure and Cortex®-M4 contexts, as far as each core is only configuring the requestor lines for the DMA instances (DMA1 and/or DMA2) assigned to itself.
Finally, DMAMUX can be allocated to:
  • the Arm® Cortex®-A7 non-secure core to be controlled in Linux® by the dmaengine framework
  • the Arm® Cortex®-M4 to be controlled in STM32Cube MPU Package by the DMA HAL driver
Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Core/DMA DMAMUX Linux dmaengine framework STM32Cube DMAMUX driver
Internal peripherals
means that the peripheral can be assigned () to the given runtime context.
is used for system peripherals that cannot be unchecked because they are statically connected in the device.
Instance Cortex-A7 S
Cortex-A7 NS
Cortex-M4
Core/DMA DMAMUX DMAMUX Shareable (multiple choices supported)
