IP Linux command line
This article provides the basic information needed to start using the Linux kernel tool: ip [1].
2. Introduction[edit source]
ip Monitoring tools ip[1] shows / manipulates routing, devices, policy routing and tunnels of network interfaces.
Template:Highlight
Template:Y Template:Y Template:Y Template:UnderConstruction
ip is installed by default (/sbin/ip) and is ready to be used with all STM32MPU software packages.
Template:Board$ which ip
/sbin/ip
It is integrated into the Weston image distribution by using the following meta-st package recipie to enable the iproute2 module: meta-st/meta-st-openstlinux/recipes-st/packagegroups/packagegroup-framework-tools.bb.
RDEPENDS_packagegroup-framework-tools-network-base = "\
   ethtool         \
   Template:Green        \
  • To check network interfaces
Template:Board$ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
    link/can
    link/ether 00:80:e1:42:43:65 brd ff:ff:ff:ff:ff:ff
    inet 10.99.1.237/22 brd 10.99.3.255 scope global dynamic eth0
       valid_lft 172057sec preferred_lft 172057sec
    inet 10.99.0.4/32 scope global eth0
    inet6 fe80::280:e1ff:fe42:4365/64 scope link
4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
  • To assign an IP address to an interface
Template:Board$ ip addr add 192.168.1.53 dev eth0
  • To remove an IP adress
Template:Board$ ip addr del 192.168.1.53 dev eth0
  • To enable an interface
Template:Board$ ip link set eth0 up
  • To disable an interface
Template:Board$ ip link set eth0 down
  • To check a route table
Template:Board$ ip route show
default via 10.99.3.254 dev eth0 proto dhcp src 10.99.1.237 metric 1024
10.99.0.0/22 dev eth0 proto kernel scope link src 10.99.1.237
10.99.3.254 dev eth0 proto dhcp scope link src 10.99.1.237 metric 1024
  • To add a static route
Template:Board$ ip route add 10.99.0.0/16 via 192.168.1.1 dev eth0
  • To remove a static route
Template:Board$ ip route del 10.99.0.0/16
  • To set the default gateway
Template:Board$ ip route add default via 192.168.1.1
5. To go further[edit source]
Some usage examples are available for reference[2].
  • Useful external links
IP Command example Standard Documentation from tecmint
ifconfig vs ip Standard Documentation
