LTTng
This article provides the basic information needed to start using the Linux® tracing tool: LTTng[1] (Linux Trace Toolkit, next generation).
2. Introduction[edit source]
LTTng Tracing tools LTTng[1] is an open source tracing framework for Linux kernel and user spaces. It is a powerful tool that can be used for many purposes. LTTng traces need to be processed/displayed with a host tool such as Trace Compass[2], based on Eclipse plugin for increased portability. Template:N Template:N Template:Y Template:UnderConstruction
This tool is composed of 3 parts:
  • lttng-ust: user space libs
  • lttng-tools: user space tools
  • lttng-modules: kernel modules
3.1. Using STM32MPU Embedded Software distribution[edit source]
OpenSTLinux embeds lttng-ust and lttng-tools by default.
The LTTng Kernel space is not installed/activated by default in OpenSTLinux to avoid increasing the roofs size.
To use LTTng in OpenSTLinux you need to both:
Symbol: FUNCTION_TRACER
  Kernel Hacking --->
    Tracers -->
      Template:Highlight
Symbol: FUNCTION_GRAPH_TRACER
  Kernel Hacking --->
    Tracers -->
      [*] Kernel Function Tracer
       Template:Highlight
Note that this trace framework is not activated by default in OpenSTLinux distributions since there is an impact on the Linux kernel size (around 1.5% increase of vmlinux), and also an impact on the overall performance, because of additional processing done to trace kernel events and function calls.
lttng is integrated in weston image distribution through openembedded-core package: openembedded-core/meta/recipes-core/packagegroups/packagegroup-core-tools-profile.bb.
RDEPENDS_${PN} = "\
    ${PROFILETOOLS} \
    Template:Green \
    Template:Green \
    Template:Green \
    ${BABELTRACE} \
    ${SYSTEMTAP} \
    ${VALGRIND} \
however, lttng-modules is removed in meta-st package: meta-st/meta-st-openstlinux/recipes-core/packagegroups/packagegroup-core-tools-profile.bbappend.
RDEPENDS_${PN}_remove = "${LTTNGMODULES}"
3.1.1. Developer Package[edit source]
It is not recommended to enable Linux kernel configuration for LTTng by using Developer Package because all external modules should also be recompiled (e.g. gcnano driver for GPU STM32MP1), and this is not possible with Developer Package (which does not necessary provide all sources).
That is the reason why this is set as 'not supported' for Developer Package.
3.1.2. Distribution Package[edit source]
Template:Highlight
  • Compile lttng-modules
Comment line meta-st package: meta-st/meta-st-openstlinux/recipes-core/packagegroups/packagegroup-core-tools-profile.bbappend.
Template:Red
Template:Green
  • Re-build the image in order to integrate new Linux kernel uImage and LTTng modules.
Template:PC$ bitbake st-image-weston
3.2. Using STM32MPU Embedded Software distribution for Android™[edit source]
The best way to get started with LTTng is to have a look to the official webpage of LTTng[1].
4.1. Activate and generate traces on target side[edit source]
Some useful information can be found in LTTng documentation[3].
Kernel tracing example[4]:
Create a tracing session:
Template:Board$ lttng create my-kernel-session
List the available kernel tracepoints and system calls:
Template:Board$ lttng list --kernel
Create an event rule that matches the desired event names, for example sched_switch and sched_process_fork:
Template:Board$ lttng enable-event --kernel sched_switch,sched_process_fork
You can also create an event rule that matches all the Linux kernel tracepoints (this will generate a lot of data when tracing):
Template:Board$ lttng enable-event --kernel --all
Start tracing:
Template:Board$ lttng start
Generate activity on your system for a few seconds. For example, start an application, load a kernel module, or list the files within a directory...
Stop tracing and destroy the tracing session:
Template:Board$ lttng stop
Template:Board$ lttng destroy
The destroy command does not destroy the trace data; it only destroys the state of the tracing session.
4.2. Import LTTng traces in a Trace Compass trace viewer[edit source]
4.2.1. Host Installation for Trace Compass[edit source]
Even if LTTng are tools running on target, the analysis of the traces generated by LTTng tools should be done with host tools like Trace Compass[2].
So first you have to download and install/run the Trace Compass tool[5]: download the last version (or at least TraceCompass-3.2.0).
4.2.2. Visualize LTTng trace with Trace Compass[edit source]
Once the trace have been generated you can use Trace Compass[2] to visualize your traces, interpreted in dedicated context view.
Template:PC$ ssh root@Template:Orange
Template:Board$
Template:Board$ exit
logout
Connection to Template:Orange closed.
Template:PC$
  • Open Trace Compass and fetch the remote trace:
  • Click on Manage profile to select/add the profile matching your setup (STBoards connection through ssh, ...)
  • If needed add a new profile: in this case, a profile named STBoards with ssh connection
  • Take care about the search path, by default Trace Compass looks for a wrong search path, please correct it
  • End by clicking on finish button
Template:Highlight
  • Your traces will be loaded on Trace Compass, and you can see them on the Project explorer on the left.
In the example below 5 traces have been loaded:
  • Open the trace
To open the trace, left-click on the Template:Highlight item corresponding to your trace, then Open.
  • Check for trace on the right panels
